Air Filter,Oil filter, Fuel Filter,Gear Oil,Throttle Cleaning along with spark plugs cleaning. Brakes service, Recently imported gp5 L varient 4.5grade in pearl white wth 15k kms on odo.Costed 21.8lac .ur costing is higher or lower then tht
Mine costed lessIts a 2013 GP5
Which brand & grade oil did you use in your GP5?Also tell me about transmission fluid which one did you use?
Do not change the gear oil and fuel filter so soon. You won't get quality stuff locally, plus our mechanics on dual-clutch transmission.... id advice against it. If you want, change both at around 80k km.
Havent changed in my car as its only 15k kms driven.Use Mobil its the best and try finding genuine air filter nd oil filter.Regarding gear oil use proper C.V.T oil and its recomended to change gear oil at 40k kms and same for fuel filter.Everything has a life and when these things loae their properties they can fatal
Finally took time to clean the carJust a Wash followed by EZ Glaze & finished off by QD wipeInterior will be done on Sunday inshaAllah
Please do say " MashaAllah "
Gp5 does not have a CVT transmission. It has dual-clutch and cvt fluid would most probably ruin it.
Isnt it the same one as vezel?
Sent from my SM-N920C using Tapatalk
took this from 2015 fit manualIm confused myself regarding transmission fluidBtw it has same Air filter kike Vezel cost almost 5800 genuine
https://vimeo.com/156836307
Regarding transmission fluid of New Fit
http://www.fitfreak.net/forums/fit-diy-repair-maintenance/91023-15-fit-cvt-fluid-change.html
Yes it is the same as vezel.
I guess you're searching it all wrong. Your car is a GP5 hybrid, the manual and link, not the video, posted above are for US model 3rd gen.fit with a cvt transmission. The hybrid i believe is only manufactured in Japan. So your only bet is getting the documents in Japanese and translating them. Or if you're lucky there might be some info available on sri-lankan automobile forums. As they too use jdm imports. https://yasithmayabandara.wordpress.com/honda-sports-hybrid/7-speed-i-dcd/
https://yasithmayabandara.wordpress.com/honda-sports-hybrid/gp5-specifications/
Took this from honda japan websiteNeed help in decoding this [emoji28]
Refer to post#418. The link I've posted has the decoded version of the same.
Thanks i checked the link and translated the Japanese language as wellThe recommendation is
" Honda genuine Ultra ATF - DW1"
help needed from fit ownersrecently got 2012 model Honda Fitchanged its oil, oil filter and airfilterEverything was fine till tonight when car suddenly did some missing After some time it started showing check engine light, rpm dropped to 1 and pick also dropped Wat can b the possible reason?
Sent from iPhone 6 Plus using Tapatalk
Could be a faulty coil or spark plug
Thanks to poor quality filter and yet poor fuel quality.Fill in pure hi octane and try to find genuine air or ai filter.I faced same problem and i imported HKS air filter and oil filter now car performs good on super aswell.
