Hi guys, can anyone briefly explain me the advantage of COOLANT ?
Coolant save your radiator from rust.
Pakistan <3
Buying undiluted coolant is much cheaper than buying diluted coolant. When you buy a 50/50 mix, you pay for 50% coolant and 50% water. When you buy undiluted, you pay for 100% coolant. Also, I live in Florida and run a 70/30 coolant mixture in all of my vehicles. Running 100% coolant has no more of an advantage than running 100% water. It's the combination of the two. Running 50/50 provides protection from -34F to +265F, 60/40 provides -62F to +270F, 70/30 provides -84F to +276.
* no need to fill the radiator frequently as coolent evaporates lesser thn water.
*as name indicates, it prevents over heating of engine.
*high boiling temperature/point thn water, so it stays for longer tym in radiator.
*better for vehicles on long route.
mainly it protect from RUST HEAT IN TROPICAL
IT Z ALSO ANTI FREEZE
50/50 RATIO IZ BEST 4 USE
Advantages:
1. it is anti rust saves radiator and car heater from choking.
2. It increase boiling point of water from 100C to around 105C so it stays longer due to less evaporation. you dont need to replanish daily.
3. Some coolent contain anti freezing agent / chemical which save icing in radiator during night parking in cold areas.
Bookmarks
