Originally Posted by
Xulfiqar
search the forums for pressure testing the system, do it and you will find your problem, also check the overflow bottle - if the pipe going into it is leaking it will not suck coolant back when the engine cools down.
If you are seeing air bubbles and the heater is connected in the system - remove carpeting and inspect the heater pipes and core for any leakage (its also a small radiator), Now put the car nose up on ramps and remove the bleeder bolt from the top radiator pipe flange and slowly rev the engine while adding coolant - squeeze all pipes a number of times to work any air upwards, when all air is removed only coolant/water should flow from the bleeder hole. Tighten and top up coolant, check for bubbles at the radiator cap. There shouldnt be any.
Bookmarks
