Engine bay cleaned
Sent from my Desire HD using Tapatalk
please reply..............
Go with manufacturer recommendations blindly as per the manual.Purchase top brand company oil. Like shell, Total, Mobil 1, Liquimoly etc. Go for synthetics if manufacturer has no issues with using synthetics.
bay for my 2013 euro 2
Good
I want to ask a question from all of you guys that Do the suzuki dealer or 3s suzuki shops uses original SGP and SGO parts and oil in the cars those come to them for change because i had a new 14 cultus from Suzuki kher Agencies karachi they don't use SGP in my car they use Guard parts every time i visit them i had visit them only two time each time they use Guard parts and don't know about the oil what they use ? All i know is just because when the third time came to change oil i decided to buy my own oil filter air filter and oil so when my mechanic was pull out previous oil air filter what i noticed is that Guard written on both oil and air filter. kindly share your views about parts
Well they should use suzuki geniune parts
but they don't use
Do they charge the same price as of sgo parts or do they charge less? If they charge same as sgo parts then complain to pak suzuki.
what are these bro?
usually suzuki just repacks the guard products esp filters so no worries regarding geniunity but yes suzuki does charge more i guess 50 - 60 rupees extra
search agoodfriend's thread "cultus engine and body overhaul".he has explained it.
hi i have got a question regarding how to check cultus whether clutch or clutch plate is working or about to give up ?i am feeling power lag as my car picks up hesitantly even on petrol & highway
i think seiken brake oil is very good
A desi way of checking clutch plate is .. put car in 1st gear pull the handbrake and then release clutch slowly, you'll feel power, if you feel like there's no power in engine then clutch plates are on ventilator . do the same for all 6 gears(including reverse)i found this method at a RENT A CAR
do some burnout
Guys i had an accident on my cultus 2 weeks ago
[emoji20] [emoji20]
Ye kia hua :o
insured ?
