car was running fine and it started to make a mess all of the sudden.carb seat and packing cant go faulty on their own,i havnt touched them until the problem arose.
plugs arent checked,cables are fine,out my friend's cables on my car and same problem.but thing is car start without any problem,even after sitting for 2-3 days,first self and its on.cables and plugs would cause problem in starting wont they? timing has been set with timing gun at company specs.
distt cap and rotor are fine physically.changed rotor but no affect.havnt changed cap will change and reply back here..
ill get plug checked though.im dubious that they could be culprit but ill check them to tick them off..
and for gear stick plate,2 bolts are on top,and 2 underneath car,just remove bolts,pull stick down,and put the plate and follow back procedure?if you can elaborate a bit,ill be highly obliged.
