I recently purchased ELM327 from a Pakwheeler, for my car JDM Alto 2004 with K6A engine having OBDII port, I used following software but I was unable to connect with ecu.
Symbian Software OBDScope installed in N8
Symibian Software autoDoctor installed in n8
When I tried to connect ELM327 With OBDScope, it starts , different coloured LEDs on the ELM starts blinking but phone software states , ?Disconnected?
When I tried to connect through autoDoctor, it tries to connect but end is Not connected
Then I installed Torq Pro on Samsung android phone, after searching all the protocols, in the end it states? Bluetooth adapter is malfunctioned or ignition switch is off.
I performed all this job with on ignition.
My car?s OBDII protocol is not supporting the device?? No
I searched thoroughly,My car?s OBD II protocol is ISO 9141-2 K-LINE
This protocol is mentioned in the ELM327 compatibility list and Torque Pro software also shows in the protocol list, but I am unable to connect.
Plz help me, is the device is not working or any other problem or I am not doing it in right way ,
