@qwertpoiuy
i believe steering Cross original/new one would cost 16,500 but since you mechanic change with non genuine/used so he took 1000
No. They do not have kharadia/machinist to take out the cross from the coupling and insert a new one. The original Toyo cross was for 650, 400 labour, 20 minutes job.
3s quoted you price for new bumper but you fixed old one different story
Still new bumper does not cost so much and they they were going to replace the trunk lid lock?
Lolz you never let them fiddle tuning its because your car was CNG and set at CNG and there is no harm if 3s touches the ecu or setting. The way you drive and your daily route constitutes a long travel not as daily city travel so yes brake pads survive and XLI GLI does not have Pre tensioner, ac belt needs to be changed at 80k
I switched to CNG after 40,000 kms and three years and the long drives started six years after I moved out of Islamabad
You changed fuel filter only once because your car was on CNG
But petrol was used 20 times daily for start up
and the conversation started from the point that your reputable supplier does not give upto the mark parts :)...
But I found the one which does give reliable parts and duly endorsed by senior and knowledgeable experienced Pakwheelers
Lastly those RENT wali corollas get no work done except for oil change and cheap filters they do never give trouble.
Yes because Toyotas are reliable
