Based on the responses received , I have consolidated the list and following has been done at Toyota 3S
Inspection:
1. Brake pads / shoes(replace if required)/ carry out front disc skimming if required = Done ,no replacement and skimming was required . As per mechanics ,it is good for another 20K
2. Suspension system (bushings etc) = Done ,no replacement required yet
3. Tie rod inner/outer ends (replace if required) = Done ,no replacement required yet
4. Drive axle joint rubber boots = Done ,no replacement required yet
5. Wheel bearings (replace if required) = Done ,no replacement required yet
Replacement:
1. Radiator coolant = Done
2. Brake fluid (flushing and replacement) = Done
3. Transmission oil along with filter = Will be done at 90K as last was done at 50K
4. Spark plugs = Done
5. Serpentine belts / all belts = Done . Vitz 2006 has only 1 belt (generator belt)
6. A/C cabin filter = Done
7. OIL & Filter = Done
8. Air Filter = Done
9. Flush & Replace Brake fluid. = Done
10. Adjust Hand Brake if Required. = Done
11. Front Brake pads = Done , no replacement and skimming was required . As per mechanics ,it is good for another 20K
12. Balance and Rotate Tyres = Pending
13. Change in tank fuel filter. = Pending
Is it really required ?. How to check if its replacement is required(as its a very expensive part)?. What if it is not replaced , can it cause any damage?
14. Radiator / cooling system hoses = Pending
Is it really required ?. How to check if its replacement is required?
15. Thermostatic valve = Pending
16. PCV valve= Pending
17. Fuel injection nozzle ultrasonic cleaning = Pending
Is it safe and worth to get it done at 80 K mark (I would go for Toyoto 3S). Are there any chances of any mess up /issues arising later due to this dismantling and cleaning process of nozzles ?
18. Throttle body cleaning = Pending
Done at 70K around 5 months ago . Do I still need to do it at 80 K ?, as in another thread experts are suggesting an interval of 30-40 K and some experts are suggesting 100K interval
Lastly is there any other item that needs to be replaced /inspected that is not in the above list?
