dear newbieeee brotheri want to give you some suugestions/advice what u can do for ur khyber (please check yourself for safety issues,legal & other related matters) it depends on yours according to your budget,your choice ,estimated price may vary i must say that u should go for mod. b/c khyber is good car to be modified
I am writing some tips,some of them i put from my own,sometimes i got inspired by other cars & did that experiment with my car,ALSO I REQUEST ALL OTHERS TO GIVE NEWBIEEE MORE SUGGESTION/ADVICE so that he or me or otherscan do some more changes
(newbieee u can do these in several steps & from differnt shops,if u can send pics of all int,ext,eng so that we can better guide you,also tell about your budget)
Internally:
internally u can do following changes:
1.Put Good & fancy seat covers on your seats (if u swith on a/c mostly then u can put LEATHER SEAT COVERSotherwise without a/c ,as khyber is small u will feel warmth & also put lether or other good covers on doors board too( if u have small children with u then put also plastic cover on doors board)
price varies from Rs.500 upward
u can install some reading lamp light (in middle & back) mostly light comes with 2 tubelight in around Rs.150 ~Rs. 400 for back seat pupil( as in khyber there is no light in middle or back {also connect those lights with all 5 doors( 4 doors + 1 back diigi) that if any 1 door is open then light will blink ,as in khyber mostly door light only connects with front 2 doors
install back brake light ,mount it near diigi door on back screen( wide RED light with several LED's) normally from Rs.100-400
4.put High qulaity rubber mate on floors from Rs.250-1000
install high quality RED light lamp on each of 4 doors so that when that door will open that light will on
put good arm rest & hand brake board( between 2 front seats ) that will cover front setas & gear & extnd uptill front dashboard,also make box for cassete rack/holder in that so that u acn put cassetes/cds safe
7.also put cup/can holder( used for racking cold drink bottle or tea etc.) either on all doors or u can install 2 can holder in same arm rest/hand brake board
8.install central locking system with good ALARM option
9.Also install some other meters (b/c in khyber there is just speedometer,odometer,petrol & temp. meter) u can add RPM meter & engine temp. meter ,engine oil pressure meter,meter of battery voltmeter which shows battery's volts ,battery ampere which shows ampers of battery.some meters with extra light such as seat belt light ,meter of detecting a/c fan( which shows at what time fan is rtunning or not).meter which shows light when u apply padel brakes ,there also comes meter which shows gear position,gear ratio,gear timing( it shows graphically on samll screen that how mcuh peak RPM u r doing & how much u can achieve maximum & which display what is current position of gear now e.g 3 means u r running in 3rd gear ,R means u have put in reverse gear
9B. if u like u can change original meter bulbs to customized blue/green/red/yellow background/led light
10.change ur stock cassete player with new deck preferably SONY XPOD system with VCD/DVD,MP3/MP4,USB PLAYER WITH 4 CHANNEL AMP WITH BOSSCHMAN 9" OR 8'' LCD N KENWOOD 6935ie SERIES SPEAKERS N 12" BOSSCHMAN WOOFER WITH PROPER BOX,ALSO INSTALL DIGITAL EXTRA DIGITAL EQUALIZER,ALSO INSTALL EXTRA ROADMASTER AMPLIFIER WITH MIC9 & put mic near your gear
11.change your 3foot pedals(accelator,brake,clutch etc.) from stock rubber to either stylish steel bigger foot pedals or to fancy biiger rubber ( by that u can rest ur feet & enjoy whle driving
12.put 2 seatbelts on back for back seated passengers
13.put steering cover( nowadays wooden color is in) so with wooden steering cover,also follow same pattern & put wooden stickers/cover on your a/c grill,dashboard lining,doors etc.
14.make 1 book holder bag on both seat cover( on back of front seats ) so that back pupil can put newspapers or any reading book inside that book holder bag
15.also buy 1 second hand or kabli wiper machine & put 1 wiper on back screen & install that wiper machine connection to same wiper button (or if u like u can add one button on dashboard for back wiper)
16.also change your front wiper blades from 1 rubber to 2 rubber on each wiper
17.also install permanently 1 bulb with transparent cover (so that bulb not damge during servicing) in your bonnet so that if in night when u open your bonnet ,that light will open (either automatically or by small button on dash board),b/c with family if any problem occurs then u have sufficient light to see & troubleshoot & not to wait others to bring lights
- also install permanently 2 bulbs in diggi on both sides so that in night when u open your diggi for changing spare tyre or finding rods,screwdrivers,tools etc. u can find all easily(otherwise in night & in dark especaillay in loadshading u will not find proper light & may be delayed in finding tools. ,that light will open (either automatically or by small button on dash board),b/c with family if any problem occurs then u have sufficient light to see & troubleshoot & not to wait others to bring lights
19.also put 1 device of 12v to220V conveter inside your car
20.also install parking sensors on back & front so that when u reverse your car & someone is behind you car will start beep OR u can also put Parking vehicle system with 4'' LCDs creen on your dashboard with samll camera on your back bumper & it starts when u put REVERs gear & start beeping & after 3 beeps ur engine will be stopped fom key automatically & thus car will stop(then u have to restart engine again)
Externally & in engine wise :
Externally & in engine u can do following changes:
- u can change your rims with fancy one( preferable JAPANESE ALLOYS,
2.change your stock tyres to either Dunlop or YOKOHAMA with size 165/../..(depending on your RIM size & various factors & ur choices)
mostly in khhyber mod, pupil use LOW PROFILE TYRES JET TINTS
3.install Bosch 2 point platinum plugs
4.change your silencer to 2.5 inch exhaust pipin with free flow (hks original exhaust)
5.put bigger CNG springs on both front & back(mostlu pupil change only on back for savings) but it is not advisable so please change all 4 spring a time ( by this u will enjoy KHYBER to atmost)
6.U CAN INSTALL AUTOMATIC SIDE MIRRORS( fancy mirrors with small machine & make them automatic side mirrors & install that automated machine near your steering on right sead beneath light button
7.when u will change ur plugs then also put high-performance wires
8,install 90AH maintenance free hi performace battery ( if u dont find main. free then go for EXIDE
9.also change your radiator pipes
10.change your a/c fan & fan cover to more fan blade(12 blade fan means 12 par wala) with high amper/volt Fan motor machine
in addition to this also put 1 extra fan ( of same either 10 or 12 blade fan) ,it will help efficiently cooling .
in stock only 1 horn comes( so u can install 2 more normal horns in differnt & far locations & in total they will be 3 with CUT-OUT & do wiring with hi performance wire
13.also put front halogen lamp( so that it can come with pure white light)
also remove your front side light covers/lens (also called parking lights )& remove normal small bulb & make a hole bigger & put new holder with bigger bulb so that even u open only side small lights, they will give enough high lights
similarly in front headlight there is only 1 holder,u can make another hole & add 1 another holder & put extra bulb( mostly pupil install yellow colour bulb), in this case without adding any exta light, ur headlight will have 6 bulbs,3 on each side ,2 in bigger head light & 1 in small parking light ( if u can then install halogen bulbs,it will be much nicer)
16.similarly in back headlight there is only 1 holder for red light ,u can make hole & add 1 another holder & put extra bulb so in back u will have this
17.also in back in revers light,remove bulb holder & now there r available holder with 8 or 16 LEDS,u can install that LED holder in indicators & revers light( u can also use this in point 16 means in replace of bulb of red light)
18.if u like then u can change all indicator covers from orange to WHITE & install orange bulb inside( 2 front bumper indicators, 2 side indicators,2 back indicators)
19.also install blue NEON light under car ,it will give much nice view
20.put 4 mudflappers with bigger one & also put 4 small mud flappers( 2 on front bumpers & 2 on back side doors),pupil put 4 additional small mud flappers so that specially when they get in reverse theire car will be clean specially in rainy seasonsby 4 stock flappers, they will help u clean only in driving forwrad but for reverse ,u can use this option .
21.also put thick rubber on all doors side (in door gaps) this will ensure safe from rust as well as small accident such as on opening door children mostly strike doors with wall or near car ( by rubber both your car door's paint will save,also wall or another car paint will safe)
22.in addition to original antenna ,also install 1 high performane bigger size automatic antenna for better FM reception on back diggi(put that antenna control with your FM settings so that antenna comes out only when u select any particular FM/AM reception otherwise it will be damage
23.install power locks with all doors
24.also if u can afford then from shershah, u can buy power windows machinery with complete circuits & install then ur car will have power windows
25.put also bonnetshield in bonnet
26.change your stock cluthplate & pressure plate to performane one
- also install power steering ( IT WILL COST U AROUND RS.8,000~ RS.12,000 ) BUT GIVES MUCH COMFORT & PLEASURE
uptill now by all above ur car look will increase slightly ( & at time of reslling u will definitely get price of above items in your cars)
28.also change your brakes to high performane one/kits with brake shows etc.
THIS POINT WILL AFFECT U AT TIME OF RESELLING ( B/C BY THIS UR CUSTOMER LIST WILL BE SHORTENED ,ONLY SPORTY PUPIL,YOUNG BOYS & VERY LIMITED WILL COME BUT THEY WILL DEFINITELY GIV. GOOD PRICE FOR IT...
28.also if u want to give SPORTY LOOK THEN
A. INSTALL spoiler on back
B. put side skurts
c. change your both bumpers
d.u can change from carberator to EFI
@rashid_ali439
pics u have sended, how much it will cost & how it can install,please reply detail,time factors,performance etc.
