Check if the heater matrix installed below the dash is not choked.
When you open the bonnet, you will see two coolant pipes going inside the cabin. One is input and the other is output of the heater matrix as the coolant is being circulated there. If the input pipe is hot and output is cold, the heater matrix is choked.
