If it's on petrol then start from carbeurator vacuum pipe's.
After that carbeurator service and proper adjustment.
If problem remains then usually something is wrong with ignition system...
Start from ignition coil after that check plug wires, plugs, distributor cap and rotor, timing advance mechanism, pulsor......
Also get your starter motor and it's solenoid checked...
Sent from my D2502 using PW Forums mobile app
