My Mehran is not going into gears after pressing clutch after starting but gears can be changed without starting
can anyone tell me issue as machanic told me that ur clutch and pressure plate may have stain (zang) which may be removed after opening it.
he told that same clutch plate or pressure plate may work or it may need to be repaired or you have to get new one.
kindly suggest me what to do in this scenario if new set should be bought then please suggest best brand and other things need to be kept while getting the work done
i always will be thankful to you
