Assallam O Alaekum. I am having some acceleration and throttle responsiveness issues that just started this season. When starting off in first gear and starting to accelerate the bike loses power/hesitates temporarily like it's not getting fuel for about a second. The power comes back and then off again cycling every second or so during low rpm. Only happens during acceleration. When I open up the throttle it hesitates then all of the sudden the engine responds.
It seems to be worse in the lower gears (1 & 2) and lessens in the higher gears.
The warmer the bike, the less issue, but even when warm and run a while it still exhibits this problem.
The bike is new just bought it last August after 1000km its ignition coil went dead then I called Safeer and he helped me out with that but after 500km I had to change the spark plug too because of the jerking and juddering on all gears.
So over all the coil is changed the plug is changed but still acceleration issues ad I mentioned in the start.
Please help me out to get rid of this issue.
Thanks
