I have purchased new gs 150 and now i need experts advice for its maintenance which lubricant oil is used and how to take its proper care and what are the necessary precaution to be kept ?
Boht Mubarak ho follow the break in period with care Change the first oil with in 200km and second on 500 odometer Try to drive on multiple speeds but not more than 65km/hKeep the bike dry
pictures of my gs 150 Brother can you tell me which lubricant oil is bes for gs 150 and whats the logic behind changing oil first at 200km and then on 500km
Sab se pehly bohat bohat Mubarak ho. Need samaj ke drive keren, racing etc se bachat karen.
sab se acha topic ap ke liy gift hay GS ke maintenance ke liyhttps://www.pakwheels.com/forums/suzuki-bikes/227387-suzuki-gs-150-making-up-durabality
Thanks fraz
Sent from my HUAWEI G7-L11 using PW Forums mobile app
CongratsLooking awesome except that skinny rear tyre which is killing its macho..
Thanks gull... really the rear tire is a look killer element of this bike
Success Is A Mindset.
Thanks mueen.... Which lubricant oil is best for gs150
Liqui Moly......
@shoaib992Congratulations for your purchase..
I would recommend using SGO oil atleast for break-in/running period.After that switch to Valvoline or Liquimoly both oil's are good.
Sent from my D2502 using PW Forums mobile app
in liqui moli which is best 20w50 or 10w40
Thanks Hassan Tahir
10w40 is normally recomended but I am using 10w60 in my Sprinter/Raider, 10w60 performance is just outstanding.
(10w40 is Rs:1,000/= per Liter and 10w60 is Rs:1,500/= Per Liter)
Brother at how many km this oil needs to be drained off and i also heard that good lubricant oil and high quality spark plug increases fuel efficiency is it true?
Nothing would happen with high quality plug use the stock one Oil should be changed soon because new engine has too many frictions and fresh oil keep it smooth and cool and improve the engine lifeI would suggest 10w40 grade Oil brand u can use any but my favourite is kixx And must use 4t oils
Liqui Moly 10w40 easily done 3,000 KM and Liqui Moly 10w60 done 5,000 KM. (I always use original OIL FILTER and also change it every Oil change whether oil change in 3000km or 5000km.)Good lubricant increase fuel efficiency but not much. Earlier my bike give me 50KM in 1 liter and after using 10w60 it give me 55km in 1 liter and also depends traffic situation.
Thanks brother
Try to stay with manufacturers recommended drain intervals... Do not extend drain interval than manufacturers recommended value doesn't matter which oil you are using.
Spark plug and good quality lubricant do have a effect on fuel efficiency but that's almost negligible.. So no need to use any fancy performance plug stay with the factory recommended spark plug.
Can anyone tell in lahore where liqui moli is available ?
Welcome To Liqui MolyHead Office:9/224, Mslim Town More, Ferozrpur Road, Lahore.Tel: 042-37566360
