Results 1 to 11 of 11
Thread: Ideal tyre size for Vitz
    mnaeem's Avatar
    Nov 2005
    43
    39
    Default Ideal tyre size for Vitz
    What is the ideal tyre size for Vitz for driving in Karachi
    SER_GTR's Avatar
    Nov 2005
    29
    9,612
    11
    443 Post(s)
    18 Thread(s)
    Hello!
    its
    165/65-70-r13
    or for some better grip chose 175/70/r13.....don't exceed above that...its enough
    genuine comes with 155/70/R13......
    Thanxx
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
    nak
    nak is offline
    nak's Avatar
    May 2006
    Peshawar
    85
    3,521
    he is right
    http://www.pro-pakistan.com/
    ________________________________________________________________________________________________________________________
    Nearly all men can stand adversity, but if you want to test a man's character, give him power...(Abraham Lincoln)
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    he is right and he is wrong....175-70-13 is the wrong size as it off by more than 5%. The other sizes are ok
    mnaeem...check the tire size calculator in the technical section.
    I would rather be exposed to the inconveniences attending too much liberty than to those attending too small a degree of it..and so restriction of free thought and free speech is the most dangerous of all subversions.
    mnaeem's Avatar
    Nov 2005
    43
    39
    But my concern is also about the low hieght of car.I want to increase height of car should I go for Yokohoma 185/65/13
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    generally...ppl will lower the height rather than to increase the height. raising the stock height can be dangerous...unless you are carrying hundres of pounds of weight in your car all the time.
    on a sharp turn....you may flip over and there may be a good cost involved in getting new shocks and springs.
    i donget ur problem...are u worried about ground clearance or your problem is grip? cuz u earlier asked about tires.
    SER_GTR's Avatar
    Nov 2005
    29
    9,612
    11
    443 Post(s)
    18 Thread(s)
    Hello!
    mnaeem....how 185 65 r13 gonna increase in height....for increment...have to change dia and aspect ratio.........but i won't suggest that....
    175 are best to fit.....Vitz got no grip problem at all...problem is that rear springs are much softer and ground clearance is lesser......result...it hits with 3 ppl on a speed breaker and here in KHi...there are no speed breakers..they are simply car breakers.....so rather you get some good softy springs with some more coils that can increase its height a bit......
    175 width is max....putting 185 makes steering much heavy....
    Thanxxx
    RedBull_ar's Avatar
    Jun 2005
    Tank
    29
    6,722
    if its a 1300cc vvti and ur gonna run it on petrol, then do not hesitate to put 185s
    Alpha Romeo 156
    Storm's Avatar
    Feb 2005
    Select City
    40,234
    8
    42 Post(s)
    4 Thread(s)
    for the 1000cc & 1300cc its 175/65R14 standard,.. hopefully i'll be fitting 205/45R16's soon on the vitz i'm buying tomorrow.
    If your going to upgrade your rims make sure the PCD is 4x100 and ET is between 38 & 45.
    Alta i'm all packed!!
    szuberi's Avatar
    Mar 2005
    Toronto
    41
    3,576
    storm...are u sure u can go 205-45-16 on the vitz...thats a two size up from 185-65-14 and not 175. check again...i have the 205-45-16 on my civic. for a vitz...it will be big and the tire might rub..here is the size on my car...the black civic.
    Ideal tyre size for Vitz -649205
    Storm's Avatar
    Feb 2005
    Select City
    40,234
    8
    42 Post(s)
    4 Thread(s)
    Salman bhai i checked that 205/45R16's just fit under the arches (while maintaining the original rolling diameter of the OEM tyre) btu i'll have to shave the inner lips of the arches. So i'm probably going to go for 185/55R15's instead. rims will have to be 14x5.5J with a P.C.D of 4x100 and an ET of 45. If i stick with these numbers i will not have to modify anything (will make driving the car easyfor my wife)
    BTW i also had 205/45R16's on my EK6
    Ideal tyre size for Vitz -651093
