There might be different service specifications for differnt models of Vitz. So be ware; for 2005+ here are the service specifications straight out of the manual:
Service specifications
ENGINE
Valve clearance (engine cold), mm (in.):
Intake 0.15â0.25 (0.006â0.010)
Exhaust 0.25â0.35 (0.010â0.014)
Spark plug type:
DENSO SK16R11
NGK IFR5A11
Spark plug gap, mm(in.):
1.1 (0.043)
Drive belt tension measured with Boroughs
drive belt tension gauge No. BT?33?73F
(used belt), lbf:
Generator belt 100_20
ENGINE LUBRICATION
Oil capacity (drain and refill), L (qt., Imp.
qt.):
With filter 3.7 (3.9, 3.3)
Without filter 3.4 (3.6, 3.0)
âToyota Genuine Motor Oilâ is used in
your Toyota vehicle. Use Toyota approved
âToyota Genuine Motor Oilâ or equivalent
to satisfy the following grade and viscosity.
Oil grade:
ILSAC multigrade engine oil
Please contact your Toyota dealer for further
details.
Recommended oil viscosity:
SAE 5W?30
OIL
Outside temperature
COOLING SYSTEM
Total capacity, L (qt., Imp. qt.):
Manual transmission 4.8 (5.1, 4.2)
Automatic transmission 4.7 (5.0, 4.1)
Coolant type:
âToyota Super Long Life Coolantâ is
used in your Toyota vehicle at factory
fill. In order to avoid technical problems,
only use âToyota Super Long Life Coolantâ
or similar high quality ethylene glycol
based non?silicate, non?amine, non?
nitrite, and non?borate coolant with
long?life hybrid organic acid technology.
(Coolant with long?life hybrid organic
acid technology is a combination of low
phosphates and organic acids.)
Do not use plain water alone.
further details.
BATTERY
Open voltage??at 20_C (68_F):
12.6â12.8 V Fully charged
12.2â12.4 V Half charged
11.8â12.0 V Discharged
?: Voltage that is checked 20 minutes after
the key is removed with all the
lights turned off
Charging rates: 5 A max.
CLUTCH
Pedal free play, mm (in.):
5â15 (0.2â0.6)
Fluid type:
SAE J1703 or FMVSS No. 116 DOT 3
MANUAL TRANSAXLE
Oil capacity, L (qt., Imp. qt.):
1.9 (2.0, 1.7)
Oil type:
Gear oil API GL?4 or GL?5
SAE 75W?90
AUTOMATIC TRANSAXLE
Fluid capacity (drain and refill), L (qt.,
Imp. qt.): 2.5 (2.6, 2.2)
Fluid type:
Toyota Genuine ATF Type WS
Change automatic transmission fluid only
as necessary.
Generally, it is necessary to change
automatic transmission fluid only if your
vehicle is driven under one of the Special
Operating Conditions listed in your
âScheduled Maintenance Guideâ or
âOwnerâs Manual Supplementâ. When
changing the automatic transmission fluid,
use only âToyota Genuine ATF Type WSâ
(ATF JWS3324 or NWS9638) to aid in
assuring maximum transaxle performance.
Notice: Using automatic transmission
fluid other than âToyota Genuine ATF
Type WSâ may cause deterioration in
shift quality, locking up of your transmission
accompanied by vibration, and
ultimately damage the automatic transmission
of your vehicle.
details.
BRAKES
Minimum pedal clearance when depressed
with the pressure of 300 N (30 kgf, 66
lbf) with the engine running, mm (in.):
With anti?lock brake system 73 (2.9)
Without anti?lock brake system 70 (2.8)
1â6 (0.04â0.24)
Pad wear limit, mm (in.):
1.0 (0.04)
Lining wear limit, mm (in.):
1.0 (0.04)
Parking brake adjustment when pulled with
the force of 196 N (20 kgf, 44 lbf):
6â9 clicks
Fluid type:
STEERING
Wheel free play:
Less than 30 mm (1.2 in.)
Tires
Tire size and cold tire inflation pressure:
Front and rear
kPa (kgf/cm2 or bar, psi)
Tire size Front Rear Wheel size
P175/65R14 81S 220 (2.2, 32) 220 (2.2, 32) 14 x 5J
P185/60R15 84T 220 (2.2, 32) 220 (2.2, 32) 15 x 5 1/2J
For sustained high speeds above 160 km/h (100 mph), in countries where such speeds are permitted by law, add
20 kPa (0.2 kgf/cm2 or bar, 3 psi) to the front tires and rear tires, but never exceed the maximum cold tire inflation
pressure molded on the tire sidewall.
Spare
Tire size Tire inflation pressure kPa (kgf/cm2 or bar, psi) Wheel size
T125/70D15 95M 420 (4.2, 60) 15 x 4T
Wheel nut torque, Nâ˘m (kgfâ˘m, ftâ˘Ibf):
103 (10.5, 76)
NOTE: For a complete information on tires (e.g. replacing tires or replacing wheels), see âChecking tire inflation pressureâ
through âAluminum wheel precautionsâ, page 262 through 269 in Section 7?2.
