AoA PWers!
Allhamdoulillah, I have just bought Toyota Vitz 2011 (KSP-130) 1.0L. Imported through JDM Import services. The car is 16K driven original.
The only issue that i am facing up til now is rough idle, which i am hopeful will be rectified easily InshAllah.
The reason for this issue can be one one of the following:
1. Bad Battery.
2. ECU re calibration.
3. Spark Plugs
I am more inclined towards attributing this issue with reason number 1. Since the car was in transit for more than a month and the battery was connected all this time, it might have resulted in a weakening of the battery. Although the car comes with original AC Delco Battery 36Ah which is just one year old according to the date mentioned on it. The idle gets rougher when i turn on the lights. Also, the lights are OEM HIDs with auto leveling system.
Any critique or suggestions on the matter will be deeply appreciated.
The few things that I will do on urgent basis is oil change, air-filter change, spark plug inspection, ecu reset, cvt oil inspection.
