5w30 is good as mentioned in manual
5W-30 is for Vitz 1.3, or 1300 cc.
Both 1.0 and 1.3
The recommended oil for Vitz 1.0 is 0W20. "5W20 and 5W30 can also be used if 0W20 is not available. But should be shifted back to 0W20 at the earliest". This is what the manufacturer says about Vitz 1.0 with 1KR-FE engine.Considering the weather here in Pakistan, 0W30 is most suitable instead of 0W20.5W30 can be used year round if mileage is around or above 100,000. OR the vehicle is driven like a racing car or for towing.
Anyone care to reply?
same question.
Do you have 1000cc one? If yes then mine also does this... Someone told me that its the belt which makes this noise... He was some mechanical engineer and said that i took my car to UET lab where i work and checked if belt was lose with the high tech equipment and said that it was lose... Local mechanics kept telling him that it was tight bit in real it was lil bit loose. He said this to me... Now i dont know if he is rite or not. Mine also does this but when engine is cool and when AC is turned on.
This is the details of oil change.. along with rates done by Toyota capital islamabad. . Are these 3S expensive or good in long run interm of quality of filter and quality of oil
I am based in Rwp and my toyota vitz 08 model steering cross joint broke yesterday. Does anyone have a contact (preferably phone #) of a shop in Sultan-Ka-Khoo or Mithu-Khan-Ahaata Saddar that deals with Vitz parts ?
Are these for Vitz 1.0 with 1KR- FE engine?
Are these for Vitz 1.0 with 1KR- FE engine?[/QUOTE]
Yes. . This is from manual of vitz 2013. There r some options and 10w 30 is mentioned there
Yes. . This is from manual of vitz 2013. There r some options and 10w 30 is mentioned there[/QUOTE]
That's the oil viscosity chart with regards to ambient (outside) temperature. Here you can see that 0W20 is highlighted indicating that 0W20 is recommended for 1kr-fe engine.
you are supposed to just tug at the belt with your finger and note how much you can pull it, how many mm, i don't remember the value, but it is that simple to test. i wonder why he needed a lab for such a simple task
Much expensive.I am using Total Quartz 9000 5w 30 its 3.25 Litres Costs me around 2200 and after including filters it costs Rs. 2700 - 3000 in Total. And i am satisfied Alhumdulillah. If u use Liqui Moly a famous, good and expensive Brand then it will cost u in Total Rs. 4200 - 4500 and then nothing will be better than this. So TOYOTA or any 3S is expensive for oil change service.
Total quartz 9000 (full synthetic oil) is an excellent oil. It's compatible to Liqu Moly standards.
Exactly Sir, Appreciated . . .
As you have said, the same can be measured with a belt tensioner tool meant for this purpose.
Hiyesterday bought a vitz 2007. guys please suggest me a good navigation for vitz in a budget of 12000 Rs.ThankyouRegards
I don't think so you will get a good navigation system in this budget, i suggest you buy an android tablet and install it in the dash , i used to drive my car with tab about a year ago
Tab thori bari ni ho jay ge in size? Even a 7" tab looks bigger due to its sides
