my vitz heat up when i give speed more than 60 km if i drive under 60 no heat up . i have clean its radiator 1 time change radiator water 3 time . 1 time clean with car wash pressure after this check radiator water after 5 days it has still rusty water what to do change the radiator or clean it more times radiator has no leakage or not repaired or change gaskit car also heatup using ac.
Seems to me like gaskit prob .. But lets see wht others have to say
did you do an acid clean yet?
this can be many things, leak somewhere causing foaming, bad water pump, bad head gasket. btw WHY did you run this engine cooling system on plain water?
Xulfiqar bhai good coolant isnt cheap , i m continously changing water after 3 to 4 days bcoz of rusty water. when i see no rust then i put coolant .how to check water pump. bcoz every mechanic have its own theory and they want to practical on your car.
Head ke qaable tight krwao aap foaming khatam ho jaye gi
Sent from my HTC One X using PW Forums mobile app
thanks for ur reply what do you mean by qablee
zic coolant 4 liter,pre diluted is about for 1200-1300..and its totally worth putting in cars.i have 1999 khyber and ive this car with me since 5 years and i only changed its coolant 2 times with zic one.. so if you see what good is coolant doin to you engine and radiator,youll stop usin water ..
yes it was clean with with acid magar acid clean se pehle bhi bubble aatay thay
Brother it seems that your engine gasket is leaking. In running engine there should be no bubbles in radiator water, get your car check from some good mechanic as this problem will cease your engine and you will hav to complete overhaul it. Also note the color of smoke from exhaust when car is heatup. if it is white then it sure that gasket is leak and water is coming out from exhaust.
brother picture is clear indication of head gasket and cylinder head problem because of over heating. 100% sure. this is not water pump problem.
heater k pipes remove kro aor un main se pressure se pani daal k chk krna. i solved my problem of dusty water that way
U people are replying to a 6 month old post
