I would rather you use Toyota genuine filters they give a person a lot of peace of mind, and since they even give you a receipt at the end of the service. If you ever had any problems due to the filter you can just go to the workshop show them the recipt and they would fix the problem for you free of charge, thats my experience with them. If you want your fluids changed outside only have your radiator fluid and motoroil changed outside I had my transmission fluid changed from a shell pump and nearly wrect the CVT transmission of the car had to then go and had the entire transmission flushed and filled with Toyota CVT oil cost me 6500/- but no problems ever since.
