So i got the oil and air filter changed and changed to zic A synthetic, the power and response of the engine has improved quite a bit.
Got SGP brake pads too, and about the spark plugs, i went and purchased them from a shop, the guy did not have the NGKs i needed, ( i wasent going to use iridium, looking for normal nickel ones ) so he sold me some densos. I regret not checking now ( only paid attention to the last few letters in the model number )
instead of this K20PR-U11 densos
i now have 4 K16PR-U11 densos
A quick read up online has told me that this is only differing in teh way heat is transferred in the spark plugs, so do i go back and change them or is it fine if i stick these ones in there?
And also it says to replace the brake fluid and fuel filter, along with inspecting very many other things.
Its a bit of a long trip to the suzuki center, and id like it to be avoided as much as possible but the manual says to replace and inspect and lube so many things i wanna die.
Is it fine if i just take care of the air/oil filters, spark plugs and engine oil and leave eveything else or do i have to go and get everything checked.
