I'm having problem with the AC of my car, its 2006 model Sirion with manual transmission imported in 2011. The AC's gas is full but the engine takes a lot of load with AC, the fuel milage goes down to 8 and to top it off the cooling is also not that good. When I stop at a signal the cooling stops. AC only works when the car is moving. I went to a mechanic and he said that I'd have to change both compressor and condensor to fix the problem. I hope you guys can help. Please let me know if the problem can be fixed
