last time when u got ur car full serviced (wash engine bay by deisal)???
@Thnanda
Ma'ashaAllah, look svery nice and beiutifull, post some interior and boot pics as well. Allah aapp ko issay handaanay kee toufeeq atta farmaey. Aameen.
Best of luck.
@asad
not full serviced but wash engine with water not diesel
some time engine area got dusty/oily and produce some smell when hot. for precationary meaures get checked some wiring from electrition too.
During hard acceleration and A/C 'ON', the compressor clutch dis-engages and engages, causing the clutch relay/it's wiring to heat up. Get the relay checked!
@thanda
You got nice car (y)
i was thinking ... can we install a switch to change the timing between two (or more) settings while running the car?this would help to change the timing setting for petrol and CNG and appropriately gaining the performance and efficiency edge...
u mean RPM setting for both CNG and Petrol???
nope... i mean spark plug timing advancement setting done through ECM
Another think, I have one setup in my mind, though manual that related to air intake... but its just a thought and will make it on paper and then discuss... its about air intake flow when on CNG and Petrol
A similar setup came in Baleno Sport, a solenoid controlled air blockage....(y)
You can get timing corrector(Timing advancer) device installed for CNG.
Air blocker looks like this:
thanks test driver this is almost what i had in mind so what is the cost of this device if bought separately?
and what is the cost of the timing correction device?
striker nice car
yes it will bethough i would recommend just adding some elfy to the round joint and moving it slowly up and down and side side so the elfy settles down but does not fix the mirror at one place. it will then be hard again and movable as well
@test driverthanx Sir gee
@strikeXgood goodshare fresh pics as wellhav u seen my car??gt it a few days ago..do share the pics after installing audio system
@strikeXmashallah nice ride , drive safe
