@ all those facing Santro's heating issue
The solution to Santro's chronic heating issue is here
This problem is actually because of weak electrical ground to the temperature sensor. It becomes even weaker with time. The solution is to give chassis ground, which is a strong ground, to the sensor. See detailed method by opening above mentioned link.
PS: Handle signaling wires with care, wrong connections may fry the ECU
