Assalam u Alikum to all.I m new to pak wheel and need little need help regarding Indus Corolla(EE 100) 96 model. I feel steering problem above 100KM especially on motorway while crossing Bus/truck, as I come to cross bus/truck car steers abit towards bus/truck and I have to adjust steering. And I have to adjust steering after crossing as well. I m first owner and no major suspension work done till today. Currently I m using Dunlop tire's 185/14/65 with 28 psi. I m facing this problem from last couple of years plz help!
Dear get tyres balanced. Issue will vanish.
Sent from my Sony Xperia P
Balancing, alignment n cambers adjustment. U may want to install a front sway bar as well!
Sent from my GT-I9300 using Tapatalk 2
bernoulli's effect...i suggest u increase distance between bus/truck and car while overtaking
@ NaXuN
+1
absolutely no problem with the car.
cut kaisay marein phir hondas ko
what should be the right tire pressure in 185/65/r14:)
Dear thanks for ur concern but 1. I do tyre balancing/wheel alignment and camber adjustment after every four months from toyota 2. Bernouli effect...... doing same thing 3. I think right tyre pressure for 185/65/R14 is 28psi correct be if I m wrong
no cutting wo be 17 saal purani car per
Its normal nothing wrong with car, secondly same will happen in someone overtakes you above 100.
if nothing wrong with my car than why I don't feel same thing on city 2000, civic 2003 and corolla 2000and one thing I forget to mention I have changed my steering assembly with used one and oil leak from front shocks( shock dead now )
Only views!come on experts
correct the front suspension and steering first.
xulfiqar bro please clear ur inbox want to pm u but u have exceeded the limit
32 and u will get good fuel economy too
I don't think so....I think 28 psi is best for normal family sedan's but experts know better!
