Results 1 to 20 of 20
Like Tree1Likes
  • 1 Post By Jeep_junkie
Thread: Replacing drum brakes with Disk brakes
    aijazkhalid's Avatar
    Dec 2012
    8
    3 Post(s)
    Default Replacing drum brakes with Disk brakes
    Hello all I have a 92 Suzuki Swift and I want to know if their is any shop in Karachi which can replace my cars rear wheel drum brakes with disk brakes. And if so where can I find such shop and how much would it cost, since the fact is well known that disk brakes are better at stopping cars the drum brakes are.
    Thank you.
    Tabish1's Avatar
    Feb 2007
    2,926
    20 Post(s)
    Replacing drum brakes with Disk brakes -1262400..........
    Pakistan <3
    mn_akram's Avatar
    Aug 2006
    Rawalpindi
    193
    4 Post(s)
    Car will loose road grip while applying breaks
    Sent from my GT-I9082 using Tapatalk 2
    Nauman
    Marwanpasha's Avatar
    Oct 2012
    20
    2,083
    71 Post(s)
    4 Thread(s)
    Quote Originally Posted by mn_akram View Post
    Explanation could help us more....!
    Sent from my iPhone using PW Forums mobile app
    Yahoo i got the app at last...!
    asad1's Avatar
    Aug 2010
    28
    2,549
    3 Thread(s)
    does any of the version of 92 swift came with rear disk brake if yes than u can replace it with original part else alteration wont work
    as it isnt an easy task u need to change hand brake setup as well
    btw why do u want to change it is ur car turbo charged or modified if not u need to service ur stock ones
    Vaqas1's Avatar
    Nov 2004
    5,024
    31 Post(s)
    Did that in my Corolla 98. Its working perfect now
    Speed costs money, how fast can you afford to go.
    Dec 2012
    8
    3 Post(s)
    you said that the car will lose grip how's that possible?
    Dec 2012
    8
    3 Post(s)
    Quote Originally Posted by asad1 View Post
    The couple of mechanics i've talked to didn't say anything about changing the handbrake setup, the reason i need to change it is that the brakes are a bit too soft for my liking even though i've serviced my stock brakes it doesn't stop my car well as the 11 camry does. It has disk brake's and stops very well and i don't have to press my brake pedal down too much, in fact i've checked and driven a couple of other cars which contain disk brakes and drum brakes in each of them the disk brakes beat the drum brakes in stopping the car faster, better and safer. Thus the reason for looking for drum brakes for my car.
    Dec 2012
    8
    3 Post(s)
    IS their not even an aftermarket version of disk brakes available for the car? As it is said that many aftermarket parts are available for cars in the car markets?
    asad1's Avatar
    Aug 2010
    28
    2,549
    3 Thread(s)
    Never go for alteration or after market local parts as safety does matter and brake isn't a piece of cake can end up to death
    Sent from my HTC Sensation 4G with Beats Audio using PW Forums mobile app
    asad1's Avatar
    Aug 2010
    28
    2,549
    3 Thread(s)
    Quote Originally Posted by Vaqas1 View Post
    Waqas Ur case is entirely different rear wheel disc brake came in Jdm corolla and they are bolt. On fit there is no issue but disc brake 92 swift is pretty rare
    Btw can u share the pic of Ur swift is like margalla?
  12. #12
    Dec 2012
    8
    3 Post(s)
    92 Swift is essentially one of the first versions of Khyber before the Suzuki company gave that design to Khyber and then changed the Swift's design afterwards so if you want to see the swift just look at any Khyber on the road right now since all the part's are the same as the Khyber.
  13. #13
    Jeep_junkie's Avatar
    Jan 2009
    194
    4 Post(s)
    @aijazkhalid, the 1992 Swift was sold in a 2 door configuration as the Cultus GTi in foreign markets. IF this car came with rear disc brakes, you might be able to use them for the swap, though I highly doubt any stuff for those cars is available in our junkyards.
    A few words of caution before you go on a wild goose chase now:
    Converting to rear discs doesn't automatically solve all your braking issues. The front brakes do >80% of the braking. The job of the rear brakes is to provide additional drag while keeping the car's rear end straight and planted firmly on the ground. Just one look at the size the tiny drum brakes on the Swift should give you a hint of how little work is expected of them. Almost any disc brake conversion you do that is not OEM for this car will be larger in size than even the front brakes causing very poorly balanced brakes and a car that takes even longer to stop.
    Rear disc brakes also require swapping to a larger diameter master cylinder and possibly bigger booster as well because of the greater volume of fluid required to operate 4 wheel disc brakes. I installed rear disc brakes on my Jeep CJ7 recently, and I still had to change the master cylinder as the pedal would sink all the way to the floor with original cylinder. Keep in mind, I didn't even use an oversize performance set up, just Suzuki Potohar discs with Corolla rear calipers (same as 86 Pajero rear calipers, but easier to install). Braking is pretty much the same as before, the main improvement being in pedal feel, brake modulation, and vehicle pitch. Now I need to modify my parking brake cables for it to work with the disc brakes. That's something you'll also have to worry about too.
    All in all that money would have been better spent on other things. It was not inexpensive and the improvement really is marginal. If you want to improve braking performance, look at upgrading your front brakes (larger discs and calipers) first. Also remember that larger alloy wheels and oversized tyres ruin braking performance. Lastly, remember that a 1992 Swift will never have the same braking performance as a 2011 Camry, short of installing Brembo binders that cost more than the car itself is worth.
  14. #14
    asad1's Avatar
    Aug 2010
    28
    2,549
    3 Thread(s)
    its is better to upgrade original one by add good booster which will be bolt on fixed this is what id did in my margalla i installed baleno booster in it and braking was damn awesome after it
  15. #15
    marrijaley's Avatar
    Oct 2012
    18
    can I disc brake my 86 rolla, and reason for that, aggressive driving, mountain shXt, bla bla...
    or any other car that would fit, so i will upgrade the whole setup to efficient setup...
  16. #16
    Dec 2012
    8
    3 Post(s)
    Quote Originally Posted by Jeep_junkie View Post
    You said to look into upgrading the size of front brake disks and calipers. So from where can i get the Best quality and resonable priced disks and calipers from in Karachi and how much should it cost me to have it replaced by my mechanic?
    Thanks.
  17. #17
    Jan 2009
    194
    4 Post(s)
    Quote Originally Posted by aijazkhalid View Post
    Thanks.
    You need to talk to a mechanic who specializes in alterations, and he can guide you best about which discs and calipers to use. The parts are available in Magazine Lane behind Tibet Centre (Plaza) or Shershah.
  18. #18
    Dec 2012
    8
    3 Post(s)
    Thanks
  19. #19
    siraj_7's Avatar
    Jun 2012
    154
    2 Post(s)
    i have a swift as well and my brakes suck as well... I need better braking as well...
    @aijazkhalid do let me know what improvements you did with your breaks once you are done
  20. #20
    siraj_7's Avatar
    Jun 2012
    154
    2 Post(s)
    double post, please delete
Similar Threads
  1. Replacing drum brakes with Disk brakes
    By aijazkhalid in forum Wheels / Tyres / Suspension / Brakes / Steering
    Last Post: 10-09-2013, 05:40 PM
  2. CG 125 Rear Disk Brakes ?
    By zuhaibonline in forum Bikes / 3 Wheelers
    Last Post: 12-06-2012, 09:42 PM
  3. Replacing rear disk brakes of 2004 Corolla with drum brakes
    By doctor in forum Member Opinions & Suggestions
    Last Post: 14-04-2012, 12:55 AM
