So can u compare its popularity to 96-2000 model or reborn 2006-2012 ?
That is why the used car price of Prosmtec shape is almost 50% less compare to reborn.
The power steering will fail, the coils will eventually fail at 80,000 km also and suspension will never adjust always go to left.
Eventually the leak of power steering oil will also lead to failure of alternator because the stupid design is that its directly below.
Not to mention that once the Prosmatec transmission requires overhaul you wont find a good mechanic in Karachi to open it and just for maintenance like torque converter and transmission filter the whole shaft needs to be opened so its a 40K expense after every 120,000 km.
These cars were only good for initial 5 years once they cross the 100,000 KM mark they will make you bankrupt in months.
A simple water pump will cost 5,500/- and a single door power motor is for 2,000 if u will go to OEM part.
