Thanks, From what i have learned, i have to be very careful in choosing the model. From the wide range of michelin models, each tire is quite different from the other.
No tire is perfect:
If you want grip and high speeds then you may have to compromise tire life and comfort.
If you want comfort and no noise then you may have to sacrifice grip.
If you want wet/snow grip your dry grip will sacrifice, and vice versa.
Then, there are all season tires, which are jack of all and master of none (which are generally most bought ) and within them are different categories of standard, high performance and ultra-high performance. (Performance meaning, speed & Grip only)
I personally am targeting to get something in high performance category.
But here is the catch, EVERY TIRE gives different feedback on different cars… mainly based on car weights.From what I have learned so far no tire is perfect:
Thats why i started this thread to see if there are other camry. owners who have installed high performance tires and see what is their feedback.
