Dear brothers
For the past couple of weeks I had faced multiple issues in my car and gradually solved one by one. After carburetor service I still had a very bad fuel consumption, missing engine, water reducing and oil seepage. Also heat up.
After showing these issues to mechanic he said there is a water(nami) in 1 spark plug (out of 3) which cause missing. It seems that it could be a gaskit issue and also need to open an engine to check if there is any water leaks in cylinders
If the matter solved by changing gaskit then it would cost 5500/- and if go to open an engine then it would cost around 25k and take 3-4 days.
This will help to overcome the issue of bad fuel consumption, missing heat up and water reducing.
I checked with 2 mechanics and both are saying for gaskit issue.
Just to keep in mind, my car is 06 VXR carb and there is no dark smoke issue, No oil reduction and alhamdolillah water dropping engine.
I need your suggestion before taking any final decision. is it look like a gaskit issue or need to open an engine.
Is there any short cut to solve the issue? You expert opinion will help to solve these issues.
Will appreciate ur response.
Thanks and jazakallah
