Results 1 to 15 of 15
Thread: AC/CNG Prob in Platz
    taaher402's Avatar
    Dec 2006
    Rawalpindi
    36
    51
    Default AC/CNG Prob in Platz
    Hi guys, my platz 2001,auto is not suppoting AC on CNG. Someone recently got it tuned from ENERCON Isb for me. Without AC, CNG is working perfectly, and on petrol AC is working perfectly ... can some one help me figure out this prob and where to get it fixed in pindi/isb/atd.
    taaher402's Avatar
    Dec 2006
    Rawalpindi
    36
    51
    ne1 wid a solution
    panicslayer's Avatar
    Nov 2008
    35
    10,044
    10 Post(s)
    It's having problem with CNG. U cannot move the car from dead stop while AC ON. Can't b removed. Live with it.
    Suggestions required
    taaher402's Avatar
    Dec 2006
    Rawalpindi
    36
    51
    yeah u r right .. ac gives problem in city traffic whn the car has to stop many times... on long drive ac can be used on cng ...bt there s got b some solution
    Nov 2008
    35
    10,044
    10 Post(s)
    There is no solution. This problem lies in every vitz and platz of that shape
     is offline
    Follow
    's Avatar
    Jan 1970
    Post(s)
    Thread(s)
    these car r under power with auto tranys
    Newbie Follow
    Im_waseem's Avatar
    Sep 2006
    Risalpur
    54
    This infact apparently appers to be the problem of two things, first definitely the engine power viz a viz body of the car and secondly availabilty of good grade oils in pakistan. I suggest to please visit a workshop named something like CONCEPT MOTOR OILS in Plot No 159, St-9, I-10/3. Tel Nos are
    0514101582-86
    They infact have imported all ranges of motor oils (especially LIQUI MOLI, a germen oil), They dont sell it in the market but change it in their workshop. Let me tell you it is economical as well.
    Go and consult them and try it once I am sure you will get the result. However can contact me on 03005294929 Waseem
    charterali's Avatar
    Dec 2004
    76
    4,502
    14 Post(s)
    It sounds more like a vacuum problem. There were vitz/platz in khi which used to fault during braking on ac/cng. But later the problem was cured by means of a bypass valve. Maybe its similar to that, consult a good mechanic.
    Jayala....
    mafzaltareen's Avatar
    Sep 2005
    2,269
    2 Post(s)
    Quote Originally Posted by panicslayer
    there are many cars working fine with a/c on cng including mine,refer to vitz owner's club
    @poster
    as you said the car has been tuned by enercon so its sensors must be working fine,the problem is in your cng settings or the advancer might be faulty.
    https://www.pakwheels.com/forumreply_az_TopicID!120546~ForumID!27~pw.html
    http://www.facebook.com/V8Rx8
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    @taaher402
    if you cannot find any solution then do this: take the car to a toyota s3 and tell them to bypass/disconnect the exhaust sensor. and then report the results.
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    i think the whole problem occurs because there is no emulator for the exhaust sensor and because of it when there is different kind of emissions from the engine when running on CNG then the ECU refuses to let any more fuel into the engine.
  12. #12
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    bump: is ur problem solved. what did u do
  13. #13
    taaher402's Avatar
    Dec 2006
    Rawalpindi
    36
    51
    i had three of the asbove options...
    1. changing oil 2.bypass valve 3.exhaust sensor
    i was thinking about these options, when yesterday myu car stopped working on cng.... nd a cng mechanic found my cng electric contacts rusty...... he cleaned them and all the problems have bneen solved including its power and pickup problem from dead stop on ac
    .............aaaahhhhh i m relieved
  14. #14
    hamad_ahsan's Avatar
    Dec 2005
    32
    203
    good to know that u got it fixed... in my case, what i have observed, if i restrict my air intake by putting some tape on pipe or inserting a rubber to make it narrower, it gives good power at low RPMs on CNG means good starts with AC and all the loads. but in that case, high RPM is restricted as the intake is choked.
    but if i make the intake pipe a little wider, performance on low RPMs is affected but gives good power at high RPMs hence it gives problems on CNG with AC on dead starts.
    Restricting air intake affects performance on petrol negatively.
    Bold and Dynamic... Second to None
  15. #15
    Retaliator's Avatar
    Apr 2006
    Rawalpindi
    8
    1,445
    13 Post(s)
    someone i know is having the same problem with the newly installed cng in vitz. thanks i ll convey the tips to him.
