Results 1 to 8 of 8
Thread: Toyota Platz Pick Performance
    hanif41's Avatar
    Feb 2009
    35
    Default Toyota Platz Pick Performance
    AOA every one. I've Toyota Platz 2003 car. It has no pick on CNG as well as petrol. On motorway its speeds doesn't go above 100 or 110Km/h. Is there any technique to boost up the pick and speed?
    smartdevil_striker's Avatar
    Dec 2006
    30
    3,359
    8
    109 Post(s)
    2 Thread(s)
    As Platz is a JDM Car... I think there is Speed Limiter in it!! Check it if its installed in yr platz
    Platinum&Iridium Plugs,Performance 8MM Wires,Automotive Bulbs and Bosch Horns for sale Contact: 0333-3035482
    Site Banned Follow
    malik593's Avatar
    Jan 2008
    Beijing
    26
    2,855
    is your platz 1.0l or 1.3l
    umaslam's Avatar
    Mar 2007
    34
    36
    Asalam O Alikum Hanif,
    since how long have u owned the car?
    Get the plugs checked.
    MAF sensor too
    Air Filter
    Fuel Filter
    Plus check for the ATF density and levels.
    I suggest u get it checked from a good mechanic.
    fahadsoulsnatcher911's Avatar
    Jul 2009
    21
    2,876
    7 Post(s)
    What is ATF ?
    ajjubravo's Avatar
    Aug 2005
    1,040
    5 Post(s)
    Automatic Transmission Fluid
    Mod Edit: Commercial selling is not allowed!
    ajjubravo's Avatar
    Aug 2005
    1,040
    5 Post(s)
    Pull your Accelerator Pedal Upwards By Your Hand,I think It is Pressed Downward By excessive Use =)
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    bro first of all these engines are not meant for CNG so u can expect all this.it already got heavy body for those tiny 1.0 engine.
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
