Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By wasay_ahmed
  • 1 Post By waleed80
Thread: Toyota Platz - Sudden hicup
    Site Banned Follow
    vyrus's Avatar
    Nov 2009
    25
    1,611
    Exclamation Toyota Platz - Sudden hicup
    Hey guys! My platz is facing this small issue for the past few days. Upon cold starting the car, when you try to drive, SOMETIMES it gives an EXTREME hicup. Like as if someone applied the brakes for a second, and then it's back to normal in a jiffy. Now, I know it's not safe to even move the car when its cold, but hey sometimes you just need to rush to your college/work, right ? Anyway, I first thought maybe my intake filter was bad so I changed it. Changed oil recently and got the car serviced. Car has been with us for almost 6 years now and it never gave us this prob what its doing now. Is it the ECU or is it mechanical ?
    Oh and it's also consuming more petrol than it usually does. Around 11km/l, usually it would do around 14. I think I need to get it tuned now, been a really long time lol.
    Injectors cleaning, throttle body servicing, anything else I should worry about ?
    wasay_ahmed's Avatar
    Nov 2006
    29
    4,959
    12 Post(s)
    its fueling problem most probably Fuel pump is going to die very soon.If you havent changed fuel filter for last 40 45k kms change tht first b4 swapin fuel u might have sum luck wth tht.Yet take care of periodic maintenance like filters,lubes plugs etc.if it has covered 1lac+ kms get its timing chain n valve clearance checked as well
    DIY The Best Workshop on the Holy Planet!
    Every thing changes,Its only the "change" which never changes.
    a4awais's Avatar
    Jun 2005
    35
    1,287
    You don't need to change anything. Your car just need a proper tune up.
    http://www.facebook.com/jadoon.awais
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    two things
    Number One..get it tuned, get the throttle body and MAF sensor cleaned
    Number Two....wake up 5 minutes earlier
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    it is the maf sensor problem,had it in my car too
    www.facebook.com/performancepartslahore
    schehxad's Avatar
    Jul 2009
    Muzaffarabad
    33
    1,330
    2 Post(s)
    just get a throttle body serviced
    SCHEHXAD
