Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By RaviAuto
  • 1 Post By Legal_rebel
  • 1 Post By jz
Thread: Platz 2003: Experts' help required
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    Default Platz 2003: Experts' help required
    Recently the acceleration of my Platz 2003 has decreased and it does not gain speed. My car went to around 80Km/h in second gear when pushed but now hardly goes to 40km/h. The engine makes a lot of noise but not speed. I went to CNG mechanic for tune up, he told me the clutch plate and the pressure plate need to be changed. As a short term measure he changed the plugs to BOSCH 4 point ones. I also got the car checked from my auto mechanic, he too told me to get he plates changed. I checked the cost of clutch+pressure plate which is around 8500 here. The total expenditure including the labor charges is 10500. My driver believes that there is nothing wrong with the car even though I can feel severe performance degradation (The drive is even bad then a Mehran).
    What do you guys suggest? I am only hesitating to go for it wondering if its really the plates or something else. Looking for some expert advice.
    FaToNe......
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    The CNG consumption has automatically increased as more acceleration is required to drive the car
    FaToNe......
    RaviAuto's Avatar
    Dec 2011
    Jaipur
    43
    Quote Originally Posted by gamemaster View Post
    I m agree with you dear, i have also CNG kit in my car...that is very cheap for me....
    Legal_rebel's Avatar
    May 2008
    N/A
    30
    1,742
    8 Post(s)
    ur clutch plate n pressure plates are fried. change them n ull get the same pick n mileage. spend extra bucks but go for someone reliable.
    Your grandchildren will likely find it incredible - or even sinful - that you burned up a gallon of gasoline to fetch a pack of cigarettes!
    jz
    jz is offline
    jz's Avatar
    Dec 2004
    26,106
    5
    185 Post(s)
    12 Thread(s)
    bosche 4tip are not meant for ur car!they are for carby cars,get rid of them.go for company recomended iridiums
    as for the clutch,u can test it ur self too.
    does the car effort alot at low rpm n goes beter on high rpms?if yes u need to change ur clutch
    www.facebook.com/performancepartslahore
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    Quote Originally Posted by Legal_rebel View Post
    @rebel thanks for your input...insha Allah this weekend will get it done!
    FaToNe......
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    Quote Originally Posted by jz View Post
    thats exactly what happens...Is it fine to go for the other plugs till these wear out? btw can u tell me what these are exactly called (the one you mentioned)
    FaToNe......
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    Thanks all for your input....It helped clear my mind!
    FaToNe......
    aantherax's Avatar
    May 2006
    33
    3,032
    4 Post(s)
    first of all converting is to CNG wasn't required CNG is not meant for these kind of cars all of the toyota FE series engines gets their valves burnt on continous running on CNG.
    ~ Be a responsible citizen and always drive safely ~
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    Quote Originally Posted by aantherax View Post
    Thats what I realized after tasting the forbidden fruit
    FaToNe......
