Results 1 to 8 of 8
Thread: Starting Problem ... Platz 2004
    azharmjan's Avatar
    Mar 2009
    39
    Default Starting Problem ... Platz 2004
    AoA Friends
    i have toyota platz 2004, 1000cc, auto transmission
    i am facing problem while starting ... its taking too much time to start after giving lot of cranking repeatedly ... previously it was on CNG but now i m running it on Petrol but the problem is still there, sometimes the engine backfires as well ... help me buddies ...
    hassan20's Avatar
    May 2005
    26
    223
    Waliakum Assalam,I cant say anything with surity but try checking coils,back fire is maybe beacuase of insufficient current and it may also be the reason for uneven starting or might be your car is badly tuned.
    jazak Allah.
    Happy Moments..Praise Allah Difficult Moments..Seek Allah Painful Moments..Trust Allah Moment by Moment..Thank Allah!
    azharmjan's Avatar
    Mar 2009
    39
    Thanx a lot hassan
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    if your car was adjusted for the CNG , the IGNITION timing was advanced for smooth running & better throttle response. On liquid fuel running readjust (retard) the ignition timing for smooth start and use light foot on throttle for better fuel economy
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    check fuel pump as in most cases fuel pump is dead or weak as when the car is on CNG the fuel pump is keep on running which ends up like this which doesn't to supply sufficient fuel
    and vitz or platz timing cant be adjusted like normal distributor car
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,591
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    @asad1 the emulator / advancer manages the ignition timing adjustment in EFI CNG kits if it starts to malfunction the timing gets screwed up by default
    Teeboyuk's Avatar
    Sep 2012
    Other
    1,608
    8 Post(s)
    Check the spark plugs... They could be burnt out..
    Pakistan.. Toyota hilux..golf mk2 gtd..rolla 2.0d..nissian sunny.. Yamaha pw 50.. Coventry uk....audi v8 d11..golf mk2 rallye..honda crx..evo 8..golf mk2 gtd..Vauxhall insignia..
    azharmjan's Avatar
    Mar 2009
    39
    thanx a lot buddies. ur suggestions are really of great help for a person like me who is totally ignorant of cars chemistry
