Results 1 to 8 of 8
Thread: best engine oil for belta. urgent help needed!!
    kazim104's Avatar
    Sep 2012
    Faisalabad
    140
    3 Post(s)
    Default best engine oil for belta. urgent help needed!!
    SALAM PWs
    i recently owned toyota belta 1000cc , ,now i want to change thier oil , air filter , and plugs..
    plz guide me that whats the best oil for my car, and what work should we do..
    thnx its urgent ,,, plxx
    asad1's Avatar
    Aug 2005
    30
    2,707
    3 Thread(s)
    Havoline formula 10w 40
    rizkhan2010's Avatar
    Oct 2011
    37
    1,858
    20 Post(s)
    7 Thread(s)
    Toyota Vitz/Belta owner's manual recommends any engine oil with grade: 5W-30
    ideally its good to change all the fluids including:
    engine oil+ oil filter,
    transmission oil,
    brake fluid,
    steering fluid,
    radiator coolant.
    (Get the odometer reading noted after all the above so as to be used for reference for the next drain interval)
    Get the condition of brakes checked,
    Get alignment done.
    also change air-filter.
    Doing all the above at one time might seem a cumulative expenditure, however, if done now, it will save you hassle for a long period of time.
    Always stick to OEM parts/ manufacturer's recommended grades & specifications.
    kazim104's Avatar
    Sep 2012
    Faisalabad
    140
    3 Post(s)
    thnxx rizkhan for detailed suggestions ...
    kazim104's Avatar
    Sep 2012
    Faisalabad
    140
    3 Post(s)
    whats about the zic A+ oil .. ? should i go for it ??
    AmeerUsman's Avatar
    Sep 2005
    Rawalpindi
    34
    1,519
    35 Post(s)
    zic A+ has grade 5W-30 and it is ok for ur car.
    faizi91's Avatar
    Jul 2011
    25
    210
    3 Post(s)
    salam bro.I have daihatsu mira e;s 660cc 2011 eco idle.I want to change its engine oil according to the manual i can use 0w-20 or 5w-30 SN so my question is which grade is best in karachi weather??? and second question is can i use ZIC OW 0w-30??
    faizi91's Avatar
    Jul 2011
    25
    210
    3 Post(s)
    Reply any one please
