Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Like Tree11Likes
Thread: Brake Fluid for all Toyota Cars
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    Default Brake Fluid for all Toyota Cars
    I've done some search for the recommended brake oils for Passo/Vitz/Boon.
    Search revealed that Toyota recommends Dot3 brake oil for all of their models like Vitz, Camry, Grand Cruiser, Hilux, etc. all the car models and recommended brake oil is Dot3 only.
    Now, in the Pak. market, the available oils are
    Dot3 LM Price Rs. 350/250ml
    Dot4 LM Price Rs. 400/250ml & Rs. 600/500ml.
    I've gone through the study of Dot4 oil and characteristically its better than Dot3.
    Dot4 is slightly expensive than Dot3, but typically Dot4 is better than Dot3 because of additional properties.
    Characteristics of common braking fluids
    Dry boiling point Wet boiling point Viscosity limit Primary constituent
    DOT 2 190 ?C (374 ?F) 140 ?C (284 ?F) ? Castor oil/alcohol
    DOT 3 205 ?C (401 ?F) 140 ?C (284 ?F) 1500 mm2/s Glycol Ether
    DOT 4 230 ?C (446 ?F) 155 ?C (311 ?F) 1800 mm2/s Glycol Ether/Borate Ester
    DOT 5 260 ?C (500 ?F) 180 ?C (356 ?F) 900 mm2/s Silicone
    DOT 5.1 260 ?C (500 ?F) 180 ?C (356 ?F) 900 mm2/s Glycol Ether/Borate Ester
    So all of friends over here, who want to change or buy the brake oil for their Toyota cars, plz go for Dot4 for better results.
    And as I mostly write that NEVER BUY OILS/FLUIDS FROM TOYOTA. Because they do not produce them. They only buy from outside, tag and make money.
    Presently the best available Brake oils are of following companies
    Liqui Moly
    PTT Performa
    KIXX
    Hope it will help.
  2. #21
    mashriqain's Avatar
    Jan 2010
    414
    17 Post(s)
    Quote Originally Posted by bradpit View Post
    The good old OEM fluid works best instead of fancy items.
    Like there is also no replacement to OEM T-IV fluid for transmission.
    Brake Fluid for all Toyota Cars - mholak8eRBDjnHuUZGUliiw
    Expensive though?
  3. #22
    margallar's Avatar
    Oct 2009
    9,960
    6
    283 Post(s)
    4 Thread(s)
    Quote Originally Posted by GoodMan7 View Post
    PTT's brake fluid was really outstanding. Firstly we used it in one of our cars. It really worked excellent. We were selling it at 180 rupee per bottle while guard's brake fluid was at 150 rupees. We tried our best to convince customers to use PTT's brake oil as its best. But people who already had mind set at Guard, barely even think to change it. So when we couldn't sell, then we drop its price same as guards. But only a very few sale. Then eventually to clean the stock (of nearly 50 bottles), we reduce the price as less than guard's , but even then it was very difficult to sell.
    Eventually we ended up with loss but after that we buy big stock of Guard's brake fluid. And till today, its very running item. Well come to do biz in pak.
    How did you compare it with the other brand?
    haters gonna hate, potatoes gonna potate
  4. #23
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    Quote Originally Posted by aamirq View Post
    mobil1 ka dot 4 bhi acha hai! dot 5 and all then mercedes bmw mein dalta hai! and 1 thing more u can mix dot4 into dot3 but u cant mix dot3 into 4 sab yeh baat yaad rakna!
    passenger mercedes benz, bmw etc use DOT4. The only original usage of DOT5 I have seen is military or race vehicles. You can fully convert your old car system to DOT5 but that calls to replace all rubber parts with DOT5 items too.
    You can also mix DOT3 and 4 without problem.
  5. #24
    NiGhTShAdE's Avatar
    Nov 2011
    29
    917
    62 Post(s)
    DOT 5 is completely different as compared to DOT 3,4 and 5.1.
    DOT 5 is a silicone based oil while others are polyethylene glycol based oils..... 3,4, and 5.1 can be mixed without a problem if operating temperature permits...
    NiGhT ShAdE>>~
  6. #25
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Quote Originally Posted by mashriqain View Post
    Expensive though?
    Rs. 850 / L imported from Japan.
    All life is an experiment. The more experiments you make the better.
  7. #26
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    Quote Originally Posted by margallar View Post
    Mainly its feedback from customers.
    Secondly we are also using in two out of three cars and its working good.
    No Guts, No Glory.
  8. #27
    mashriqain's Avatar
    Jan 2010
    414
    17 Post(s)
    Oh, where is this price from?? It's good. Please let me know if Toyota 3S.
  9. #28
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3990 Post(s)
    94 Thread(s)
    6
    Is this feedback on just topping off the brake fluid or a full flush of the old fluid with new.
  10. #29
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    mostly its full flush and we advise the same too.
    but yet some customers only do the top up.
    No Guts, No Glory.
  11. #30
    bradpit's Avatar
    Nov 2010
    42
    2,064
    87 Post(s)
    2 Thread(s)
    Brother its available everywhere in KHi if you have any relative here or let me know.
    What is the dealership in your city offering the rates for that ?
  12. #31
    mashriqain's Avatar
    Jan 2010
    414
    17 Post(s)
    I just got off the phone with a Toyota 3S here and they are saying it only comes in 250ml bottle (I guess referring to the same bottle which I already have) and costs 875 Rupees. I have already purchased one 354 ML bottle of Genuine Toyota Brake fluid from a reliable parts shop here for 450 Rupees. Another selling the same for 520 Rupees. I called them as well and they said Toyota brake fluid does not come in 1 liter bottles... Can you please tell me the part number written on the bottle so that I can look in more detail??
    and HAHA, I was further told by Toyota 3S on phone that it only takes ONE bottle to flush the whole brake system, it was a parts guy who inquired from someone behind him whether my car takes the same brake fluid as the rest...
  13. #32
    mianaasim's Avatar
    Nov 2013
    264
    2 Post(s)
    Toyota is selling brake fluid in 354 ml bottle packing. But there are two part numbers mentioned with different pricing:
    1- DOT 3 Part # 08823-80010 354 ml
    2- DOT 3 Part # 08823-80010-10 354 ml
    one is priced Rs 460 the other is priced Rs 760. I dont know wat is the difference between them.
    For full bleed and fill requires min 1 liter brake fluid.
  14. #33
    mashriqain's Avatar
    Jan 2010
    414
    17 Post(s)
    Quote Originally Posted by mianaasim View Post
    1- DOT 3 Part # 00823-80010 354 ml
    2- DOT 3 Part # 00823-80010-10 354 ml
    Thanks for the response! Strange about the added 10 there on one of the product. I think there's a typo in your post though, the DOT 3 Part no. starts with 08823.
  15. #34
    mianaasim's Avatar
    Nov 2013
    264
    2 Post(s)
    sorry, its not 10 its 01 the complete part # of 2nd one is 00823-80010-01. I am also wondering wat is the difference
  16. #35
    ehalin's Avatar
    Sep 2006
    Multan
    44
    402
    10 Post(s)
    12 Thread(s)
    I'm going for a brake oil change/flush for my car. Pl elaborate which "feel test(s)" to be carried out before, during and after the procedure. Pl give a step by step procedure or should I just close my eyes and "feel" the brake lines for "heat" or anything unusual.
  17. #36
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    Quote Originally Posted by ehalin View Post
    Please "feel free" to do it.
    Well, zulfiqar has already explained it i think within this thread or somewhere recently. Its not v. complicated and almost applicable for all the cars.
    No Guts, No Glory.
  18. #37
    mianaasim's Avatar
    Nov 2013
    264
    2 Post(s)
    hahhahahahha. "Feel" Free. haaahahahahhaha. wata shaat.
