Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 98
Like Tree12Likes
Thread: Best Engine Oil for Toyota Belta 1.0 2010 1KR-FE
    Maverickz's Avatar
    Apr 2008
    86
    131
    4 Post(s)
    Question Best Engine Oil for Toyota Belta 1.0 2010 1KR-FE
    AA,
    I have recently bought Toyota Belta 1.0L. It came with original engine oil which was in reasonable state but I still changed it to ZIC A+ (as I always used ZIC A+ in my Vitz for last 4 years). Since then I am not satisfied with engine's noise and feels engine is not running so smooth....
    So I would appreciate if you guyz could suggest me some other oil ... howz the original Toyota Engine oil ? Is it better in quality than others available in market like Shell, Caltex etc ?
    And one more thing I read somewhere online that for Belta 5/20 Engine oil is used and I have read somewhere that 5W/40 is more suitable oil in pakistan conditions, so can I use 5w/40 in car which says to use 5W/20 ?
    Thanks in advance for your expert opinions
    Maverick
  2. #61
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    Quote Originally Posted by syncview View Post
    Indeed, indeed.
    i like the people who always keep their minds enough flexible to adopt and learn new things and understand them logically with practical, experimental & factual grounds. Cheers.
    No Guts, No Glory.
  3. #62
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Quote Originally Posted by GoodMan7 View Post
    Indeed, same here.
    https://www.facebook.com/OsamaAbbasPhotography
  4. #63
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    Indeed, same here.
    pleasure to meet.
    Which car do you have and feeding oils?
    No Guts, No Glory.
  5. #64
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    even if someone will pour c-oil in the engine, even then it will work.
    But thicker oils does no good in the cars and neiter the engine is happy with them.
    Synthetic oils provide outclass and more long lasting lubrication than the thicker oils. So its not wise to feed the new cars with thicker oils like 20/50 or 10/40.
    Example,
    i have new car and i feed it 20/50. I will get average like 10km/l and change intervals would be 4~5k max.
    Keep using this oil and i have to start going workshop before 100k.
    I feed it 10/40. I will get 11km/l and change interval would be 5k max.
    Keep using this oil and i will take my car to workshop to see mechanic on/before 120/130k.
    I feed it zic a+ (5/20) or similar grade oil. I will get 12km/l and change interval would be 5k.
    Keep using this oil and i will take my car to workshop to see mechanic on/before 170/180k.
    Now i feed my car with fully synthetic oils like 0/40, 0/30, 5/40, etc. I will get 14~15Km/l and change intervals would be 8~10k.
    After driving car 200k, its engine will be healthy and young to go another 100k easily.
    I Know What You Told......We Are Talking Engine Oils Here.........Not Gear Oils...So Stick To POINT.....!!
    I Am Asking Why 10w-40 Won't Work As You Say NEGATIVE....!!
    The Way You Are Explaining Things Mean Something Like -10W-30 Will Make Your Engine Go Immortal
    No Mechanical Work Ever....
    This Is Something Out Of Books And Logic............!! Increasing Viscosity Results In Engine Damage As You Explain Above
    In Simple........The Old 80's And 90's Should Have Not Lasted 300k .... Why Is That So....They Use 20w-50 ......No Fancy Stuff.....Clean And Simple.....And They Last 300k + KM...Depending On Maintenance....
    So This Claim And Example Seems Improper To Me.........!! I Can Agree On Mileage You Get As Thin Engine Oil Will Put Less Stress On Oil Pump And Produce Less resistance But On Other Hand......If You Say It Can Dramatically Multiply Your Engine Life For Like 2 Times...Then Its NOT......!!
    If Its That's So...The Owener Manual Should Have Deleted 20w-50 And 10w-40 Viscosity As They Will Make There Cars perform Less Than Expected.....!!
    And Do Consider The Weather Conditions Here..........The Long Change Intervals Are Always Doubtful Due To Dust And Moist Weather Conditions We Go Through......!!
    So Its Better To Stay On Mild Track And Use All Season Compatible OIL....And Why Spend Double When You Can't Go Above 5k Km Interval Change With Conditions Around........Those Fancy Expensive Oils Are Meant To Be Used For Better Performance Once But Can't Be Used As Miracle OIL.....!!
    TOYOTA Sprinter 86- AE80 DOHC 20v'D TOYOTA Corolla 98- AE101 4AFE 16v
  6. #65
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    Quote Originally Posted by SER_GTR View Post
    sir, i really wish to reply each and every point that you wrote. But it seems that i have to start again from the abc. Plz get some time to.read some more posts here on synthetic oils.
    However, this is for sure that i cannot give more simplest example to poke your deeper intellegance.
    Most of the old mechanics will be agree wth this post who believe that only the best oil available in pak is 20/50 and we should use it from begining to the entire engine's life.
    No Guts, No Glory.
  7. #66
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    It Was Given As Example ...I Never Said That............Nor I Recommend 20w-50...
    Point Is I Don't Understand Your Simplest Examples As They Makes No Sense To Me....!!
    Synthetic Oil Is Better In Many Aspects Doesn't Mean As Much As You Explain......!!!
    I Am Just Not Satisfied WIth This Miracles Of Synthetic OIL
    Not Everyone Can Use That Doesn't Mean They Are Doing BAD With Their Motors....!
  8. #67
    SER_GTR's Avatar
    Nov 2005
    30
    9,737
    16
    489 Post(s)
    19 Thread(s)
    As Soon As They Are Using Right Grade And Recommended Viscosity......They Are Doing FINE.....!!
    Fake's Are Not An issue Of Manufacturers.....
  9. #68
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    it always take some time for people to get familiar with new things and understand their proper uses, properties and characteristics.
    But in Pak. it take years or perhaps decades before people even start thinking about any change, generally.
    Sir, i request to enhance your studies about synthetic oils. There are no miracles in their performance. But ofcoarse we feel ourself much satisfied with their ultimate functionings.
    No Guts, No Glory.
  10. #69
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    engine oils has mainly 4 categories (racing cars technologies not included).
    Fully synthetic
    semi synthetic
    partially synthetic (or with synthetic formula etc.)
    mineral oils.
    Increase your study and awareness before pointing others.
    Thanks.
    oils are more than just these marketing lingo,
    the base stock choice, the blending of others bits in it to satisfy the performance specs of different API specs or ACEA specs is taken into consideration.
    How come people on PW assume that these API levels were just synthetic and mineral and just gaarha or patlaa haail, there are a bunch of mineral limitations in action here, specially oils formulated for DI engines - those engines face a lot of oil thinning due to fuel dilution.
    Now before just talking about thick or thin please talk about more realistic stuff - e.g. why API specs are in place - not just viscosity numbers.
  11. #70
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,402
    131
    3989 Post(s)
    94 Thread(s)
    6
    a little question for goodman,
    if I give you a few oils to choose
    1 mobil1 0W40
    2 Shell Rotella/Rimula 5w40
    3 Castrol syntec GTX 5w30
    4 regular mineral 5w30 with SL API rating
    which would you choose to use in a mercedes benz E430 from 2002? and why?
    p.s. mercedes benz recommend an oil with a min viscosity of 12 cst at 100C and this engine uses a total of 4 cat converters, has roller tappet rockers and holds 9 litres of engine oil.
  12. #71
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    pleasure to meet.
    I have a mehran and using caltex delo silver 15w-40.
  13. #72
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    1 mobil1 0W40
    if its your car, then.it should be 0/40 for sure. Because you already mentioned in your previous posts about it.
    Otherwise, first we always ask which oil is being used previously and changing intervals. After knowing it, a more precise suggestion is made in order to increase engine's performance.
    Its pretty simple.
    No Guts, No Glory.
  14. #73
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    perfect choice of viscosity. Good keep using.
    Or if possible, use zic-m (15/40). Its perhaps better oil than caltex.
    No Guts, No Glory.
  15. #74
    GoodMan7's Avatar
    Apr 2013
    1,407
    8
    69 Post(s)
    very surplus information for common car owners. Perhaps only less than 0.001% people must be knowing about it. Am driving car since longtime n never wanted to go so deep to know viscosity of abc cst and at xyz temperature etc. It would be similar to calculate the calories in food before eating all the times.
    I am not an engineer like you sir, just a common guy with a bit of interest about oils.
    No Guts, No Glory.
  16. #75
    muh_farooq's Avatar
    May 2007
    Other
    32
    324
    3 Post(s)
    Brthr delo silver is for diesel engines
    "THERE IS STILL SO MANY HAPPINESS IN THE WORLD"
  17. #76
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    zic-m is API SJ
    delo silver being an SG suits better to my car's engine
    i don't believe in the concept of API ratings being "backwards" compatible for reasons stated above by experts
  18. #77
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    exactly, that is why I believe that the common car owner should just follow what the manual states.
  19. #78
    ifahadn's Avatar
    Sep 2010
    114
    2 Post(s)
    Used twice LUB PLUS bodro oil so far after zip A. It was noticeable change in engine sound. Engine now more noise less even after 4000km run. This Oil is made in Germany & only available in Plaza. It is a bit expensive but try it u will keep using this Oil.
    Sent from my iPad using Tapatalk HD
  20. #79
    Maverickz's Avatar
    Apr 2008
    86
    131
    4 Post(s)
    @GoogdMan7 and @Xulfiqar
    If I have to pick between Mobil1 0W-40 and Liqui Moil 5W-40 which one should I pick for 1KR-FE engine ?
    And are these oils SAE complaint ?
    BTW the owner of oil shop from where I get my car's oil change , according to him Mobil1 is the best oil and then others are in this order
    1- Mobil1
    2-Kixx
    3-Liqui Moil
    4-Performa
    Thanks,
    Maverick
  21. #80
    syncview's Avatar
    Apr 2006
    28
    3,364
    7
    436 Post(s)
    2 Thread(s)
    Quote Originally Posted by Maverickz View Post
    1- Mobil1
    2-Kixx
    3-Liqui Moil
    4-Performa
    Thanks,
    Maverick
    there are many different variants for the LM 5w-40, which one exactly are you talking about?
    Also get the same info for the mobil1 0w-40
