Results 1 to 16 of 16
Thread: Toyota Belta - Loosing power slightly while shifting gears
    bilalrashid's Avatar
    Dec 2005
    35
    102
    Default Toyota Belta - Loosing power slightly while shifting gears
    Hi guys,
    I own a toyota belta 2006 model which I recently bought. The car looses power slightly when shifting gears. The car is running fine otherwise. Somebody told me it could be the MAP sensor which is causing this. Any direction or advice will really help.
    Bilal
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    your belta shifts gears?
    Dec 2005
    35
    102
    when the auto shift happens I meant
    usman_arooq2's Avatar
    May 2011
    Sialkot
    1,437
    13 Post(s)
    Quote Originally Posted by bilalrashid View Post
    maybe it is doing this for smoother shifting, it is supposed to do that under normal driving, try to floor it and see if u can feel more aggressive shifiting.
    Bella, You give me everything just by REVing - NEONLIGHT SAGA: NEWTUBE
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    the belta transmission cannot shift, its got a variator, the rpm will more or less stay stable as the car accelerates.
    Dec 2005
    35
    102
    It looses RPM pretty significantly... you get a proper JERK ... so its not like its a 50 - 100 rpm drop ...
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,578
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    sounds more like transmission problem. any transmission fluid / filter changes since purchase? NO ! - do it now before break down of CVT transmission
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    your concept of the transmission that is in your car is wrong, firstly it cannot shift at all, there are no gears, its got a couple of pulleys and a belt.
    The transmission should never jerk in any case, Connect it to a proper scan tool and test the unit, Do a full recalibration (including fuel pressure recalibration) and retest.
    Did you take off the battery terminals to reset anytime soon?
    huzaifa.haroon's Avatar
    Aug 2012
    4,993
    10
    222 Post(s)
    7 Thread(s)
    Toyota's CVT in Belta kind of shifts gears if you keep going on a constant speed but that too at a low RPM but then it works like a CVT no jerk no nothing , people who are new to CVT may thing that its a problem
    Treat others the way you want to be treated
    Always respect your parents
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    it does not shift gears in any condition, the slight jerking you feel is wrong - its either due sloppy engine mounts or your variator hold pressure is too high and the PCM is unable to control it smoothly.
    I have repaired and calibrated a few jatco units which are 90% similar to this toyota unit.
    Aug 2012
    4,993
    10
    222 Post(s)
    7 Thread(s)
    I drove belta and mira es both do the same it changes one gear at speed of around 10-20 km/h , not exactly a gear but an rpm drop
  12. #12
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    that is not a gear change but the pulleys are starting shuttle, low load condition the torque convertor lockup also starts its job (you can hear it as a buzz sometimes)
    You should not be feeling it in the body of the car, only seeing it on the rpm needle.
  13. #13
    Aug 2012
    4,993
    10
    222 Post(s)
    7 Thread(s)
    Oh yess its just the rpm from 2k-1k something! But not like a gear change or jerk
  14. #14
    Dec 2005
    35
    102
    just ordered a OBD II scanner will hook it up and test all the systems when it arrives will revert soon
  15. #15
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    93 Thread(s)
    6
    unless its a very comprehensive system - it wont help you with the CVT. There are 2 more systems that need to be reset - which a handy scanner (unless something like a maxidas or techstream) is incapable of.
  16. #16
    saoud.arshad's Avatar
    Aug 2013
    Gujranwala
    26
    242
    17 Post(s)
    Bhai would u mind 2 share some pics of ur beauty with us
    Sent from my A10 using Tapatalk
