Results 1 to 8 of 8
Thread: Help required "elm 327 config with toyota platz 2004"
    naumantariq2558's Avatar
    Nov 2012
    Peshawar
    27
    Default Help required "elm 327 config with toyota platz 2004"
    have recently bought elm 327, tested it with yaris, its working fine but cant make work it on toyota corolla x 2003 and toyota platz 2004, have tried it on both using TORQUE PRO and hob drive but not successful, have "tried toyota jdm can21" as suggested on forums of hob drive and also have tried several initialization strings too but no luck. looking forward to step by step guidance to make ELM 327 work on platz and corolla x
    thanx Help required &quotelm 327 config with toyota platz 2004" -1503006
    Nov 2012
    Peshawar
    27
    Have tried following init strings:
    ATIB 96\n ATIIA 13\ n ATSH8213F0\n ATSP4 \n 0100
    ATIB\nATIIA13\nATSH8213F0\nATSP4\n0100
    ATSH8213F1\nATIB96\nATIIA13
    ATIB96\nATIIA13\nATSH8113F1\nATSPA4\nATSW00
    ATSP6;ATAL;ATSH7EO;ATCRA7E8;ATST32;ATSW00
    (in torque for next line \n is to be used may be i wrote thus wrong will confirm, i copied this string from hob drive selecting "toyota jdm can21")
    have tried these vehicle profiles
    toyota celica
    toyota comon
    jdm toyota caldina 2004
    toyota jdm comon
    toyota jdm can mode21
    with several protocols
    all ISO and CAN protocols
    ISO 9141-2
    ISO 14230-4(5B INIT, 10.4K BAUD)
    Nov 2012
    Peshawar
    27
    still waiting for reply
    Nov 2012
    Peshawar
    27
    any sort of input is most welcome
    Nov 2012
    Peshawar
    27
    bump!!
    Nov 2012
    Peshawar
    27
    bump!!
    ZainMahdi's Avatar
    Dec 2012
    22
    928
    50 Post(s)
    Check out this thread (post#55). This same thread suggested the use of the first line of code that you tried (ATIB 96 \n ATIIA 13 \n ATSH8213F0 \n ATSP4 \n 0100); it didn't work for you. Post #55 basically suggests the use of a Tachyon bluetooth reader. Perhaps you might want to google Tachyon, and source one?
    Here is a guy trying his Tachyon in a JDM Allion. This is a youtube link; copy and paste the link address in a proxy. Apparently, the software he is using is Tachyon specific. In theory, Torque Pro and ELM327 should work for you, though.
    This is all that my 15 minute google search yielded . I was actually searching for obduino JOBD; I happened to come across these links.
    Nov 2012
    Peshawar
    27
    @ZainMahdi
    thanx man
