Results 1 to 18 of 18
Like Tree5Likes
  • 1 Post By Glioblastoma
  • 2 Post By capsat
  • 2 Post By Khurram26
Thread: Belta Engine swap 1.0 to 1.3 or 1.5
    hasanyusaf's Avatar
    Jan 2009
    Rawalpindi
    33
    498
    4 Post(s)
    Lightbulb Belta Engine swap 1.0 to 1.3 or 1.5
    AoA fellows,
    I have 2006 belta 1.0. its 1KR-FE and the engine is weak.. vibrates at idle and vibrates horribly with AC on.
    No smoke at all during normal running but at max RPM there is thick white smoke. engine oil is not reducing at all. I hate the loud noise of 1KR as well. have spent a lots of time and money on replacement of oils/lubricants/coolant/plugs/o2 sensor and much more but the engine performance is still unsat... so finally ive decided to replace it with a 1.3 or 1.5 engine...
    Im in karachi... went to shershah... a belta halfcut was available for 140k.. complete with a 1.3 engine and suspension... any comments on price?
    Plz share from which mechanic in Karachi should I get the job done?
    what will the whole swap cost including price of engine?
    is it advisable to swap with a 1KR engine block and keep wiring and ECU orignal or shud I go for 1.3/1.5 engine? In that case do I have to replace wiring/transmission as well or the orignal ECU will work with the new 1.3 engine?
    Ur Attitude determines Ur Altitude!!!!!
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    I would suggest complete swap with uncut wirring 1nzfe (1.5) is cheaper than 2nzfe
    hasanyusaf's Avatar
    Jan 2009
    Rawalpindi
    33
    498
    4 Post(s)
    Thanx for the quick reply brother...
    Plz confirm 2nzfe is 1.3?
    Glioblastoma's Avatar
    Oct 2012
    316
    27 Post(s)
    You can see engines here at gharibabad the guy is Imran Mannan 0321-8221732, 0347-2000300.
    For electric wiring a pakwheeler by the name of lowresolution said polo at hyderi market is the best. For mechanic you can take advice from vicky 03002761044.
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    Quote Originally Posted by hasanyusaf View Post
    Yup 2nzfe is 1.3
    NiGhTShAdE's Avatar
    Nov 2011
    29
    917
    62 Post(s)
    Yes it is 1.3. Same engine that comes in local 1.3Xli/Gli so it would be easier to maintain compared to 1 NZFE...
    NiGhT ShAdE>>~
    hasanyusaf's Avatar
    Jan 2009
    Rawalpindi
    33
    498
    4 Post(s)
    Quote Originally Posted by Glioblastoma View Post
    so nice of you brother.. Jazak Allah...
    I'll contact the person u have mentioned...
    hasanyusaf's Avatar
    Jan 2009
    Rawalpindi
    33
    498
    4 Post(s)
    expert advice is welcome...
    in my own opinion if i have to go thru the whole swap process... i wud prefer 1NZ-FE (1.5) over the 1.3...
    the question is how much alteration or extra parts change wud be required... like engine foundations etc...
    which gearbox comes with 1NZ by default???? is it the same CVT that is with 1KR (1.0) or is it auto tranny?
    capsat's Avatar
    Apr 2006
    Select City
    10
    12,594
    31
    6
    1017 Post(s)
    19 Thread(s)
    5
    6
    Your current Transmission will mate with 2nZFE without a problem as well.
    visit the above 2 places alone between 11.30 am to 5.30 pm on your own check prices and avlblty. have patience to ask all question about wiring ecu, tranmission, mountings etc etc. It is your money so be specific & explicit for all your tech questions.
    After that call up Irshad 0300 2237538, seek his opinion without sharing your knowledge base, visit and ensure that you tag along to select an engine with Transmission. bargain heavily and at finalization ask how much will be adjusted for your older engine. -do not forget to take receipt with engine cc and engine number clearly mentioned. that will help you for registration book endorsement of engine number.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    BTW while buying engine make sure you don't get your hands on a locally used engine
    ELblingo's Avatar
    Sep 2007
    25
    473
    2jz duh LOOL
  12. #12
    Khurram26's Avatar
    Dec 2006
    38
    275
    13 Post(s)
    AoA fellows,
    Belta half cut with 1.3 is a very good option. In fact I will say that it is better than 1.5
    The reason why I say this is, that when you buy the half cut, you'll get everything.. the engine, transmission, mounts, axles, wiring, ecu, sensors, suspension etc which you can bolt on directly to your car without any alteration.
    This will be as close to a factory fitted 1.3 as it can get, and later on you won't have any problems either.
    1.3 will give you a very reasonable drive and pulling power and you will never feel that the engine is underpowered like you feel in 1KR
    If you go for 1NZ, you will have to run around in collecting parts separately since you won't find a complete 1.5 nose cut for belta. And then it will involve modifications.
    Lastly, believe me, 2NZ is less noisy than 1NZ. That is, 1.3 makes lesser noise than 1.5, which is inherently a loud engine.
  13. #13
    hasanyusaf's Avatar
    Jan 2009
    Rawalpindi
    33
    498
    4 Post(s)
    thanx @capsat sir... im outa karachi on sarkari duty... will be back by monday... will have a lots of time... for research on a reasonable halfcut for belta...
    after the engine gets perfect IA ill get the cosmetics and audio setup... wil share pics of the shershah and gharubabad market here...
  14. #14
    mallic's Avatar
    Jun 2005
    48
    305
    6 Post(s)
    do share your experience as I am about to be going through same procedure...will learn from your experience
  15. #15
    saboor73's Avatar
    Oct 2013
    10,553
    25
    351 Post(s)
    14 Thread(s)
    6
    25
    update??
  16. #16
    hasanyusaf's Avatar
    Jan 2009
    Rawalpindi
    33
    498
    4 Post(s)
    Apologies for dissapointment.
    Engine change was a very time consuming and costly option...
    I sold it at a loss...
  17. #17
    waleed911's Avatar
    Sep 2011
    487
    16 Post(s)
    so u dint swap?...
    Driving is not about going from point A to point B, it is the point...
  18. #18
    Alpina's Avatar
    Jun 2010
    Chiniot
    27
    16
    Salam. I also the same Vitz which is giving me same problem. White smoke on flooring, no smoke in normal running, it is not lowering the Mobil oil levels but the engine sound on idle is very loud and doesn't seem healthy.
    You can actually tell that the car is coming from a distance.
    I need a suggestion regarding engine overhaul or engine swap. Please help.
