Results 1 to 10 of 10
Thread: Want to replace CV joints of Toyota Belta
    tehxib.alvi's Avatar
    Nov 2013
    32
    Default Want to replace CV joints of Toyota Belta
    want to replace CV joints of toyota belta, any suggestions plz, how much it will cost
    tintin1's Avatar
    Jan 2014
    1,829
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    First call these guys to know the prices of CV joints.
    Tell them model and they will inform you the availability and prices.
    New Iqbal Autos (Montgomery Road)
    36313258
    32407168
    0333-4056401
    Fine Autos (Montgomery Road)
    36313381
    36374502
    36313384
    Toyota House (Montgomery Road)
    36291188
    0333-4056401
    0321-4056401
    Buy the new one, go to mechanic. Mechanic will hardly take PKR 1000/- for fitting/unfitting. But Kharadiya will take 2500~3000
    Tips:
    1. The original boots comes with new CV joints. however if it doesn't, then buy the original ones by yourself. Don't let the Kharadiya sell you his boots from his stock.
    2. Buy one pack of Grease by yourself and ask Kharadiya to apply your given grease instead of his own. Usually new boots comes with Grease also. But if it does not, then buy your own.
    3. To know which grease to apply, in the mechanical forum read thread "Grease" started by Xulfiqar.
    Be Addicted To Help Others.
    abid110's Avatar
    Jan 2014
    3,884
    90 Post(s)
    Quote Originally Posted by tintin1 View Post
    36313258
    32407168
    0333-4056401
    36313381
    36374502
    36313384
    36291188
    0333-4056401
    0321-4056401
    Tips:
    What does kharadia do?
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,958
    32 Post(s)
    Quote Originally Posted by abid110 View Post
    take out the cv joint from the drive shaft and fix the replacement on it
    abid110's Avatar
    Jan 2014
    3,884
    90 Post(s)
    Quote Originally Posted by Fahad.Ayub View Post
    You mean altering the axle rod? Making new grooves etc? That heavy machine which suspension people keep in their shops
    tintin1's Avatar
    Jan 2014
    1,829
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    he will shift the Grease filled boots to the axle. Normally with the help of press, i believe.
    More than 90% car mechanics don't do by themselves. Thats why they take the axle to kharadiya to shift boots on axle.
    tintin1's Avatar
    Jan 2014
    1,829
    7
    61 Post(s)
    2 Thread(s)
    7
    5
    And here is the thread about Grease.
    I guess you need NGLI-1 or 2 grade Grease. And plz don't compromise on Grease because it plays important life in axle's life.
    Fahad.Ayub's Avatar
    Aug 2013
    21
    1,958
    32 Post(s)
    no just replacing the joint on the rod and greasing and packing it
    Nov 2013
    32
    Thanx bro
    Xulfiqar's Avatar
    Aug 2003
    Other
    38
    24,399
    131
    3987 Post(s)
    94 Thread(s)
    6
    toyota cv joints have a trapped C clip which will break when the joint pops loose. That is why toyota dont sell the outer cv separately from the shaft.
    make sure to get a new C clip for the joint and use the correct black moly grease on the outer joint (max 90 grams) - new joints have the grease sachet inside the box.
    The inner trilobial joint takes wheel bearing grease.
