Results 1 to 20 of 20
Thread: 14s for Platz. Feasible ?
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    Default 14s for Platz. Feasible ?
    hi guys. i m planning to get 14 inch rims. just wanted to ask whether the size is too large or not. and with 185 tyres on 14s, my meter reading wud be wrong. is it possible that i get my meter calibrated somehow on 14s ? i have heard its done somewhere
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    what is the stock tire size?
    its all about power to weight ratio...
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    stock is 155/80/13
    i m currenty using 185/70/13
    RetardedBuddy's Avatar
    Sep 2008
    Select City
    7
    13,785
    2 Post(s)
    i guess they will
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    will recommend you the stock size, it works the best for fuel economy and suspension setup... still if you want the bigger size than here are the caclulations
    with 155-80-13
    your overall diameter is 22.76inch
    with 185-70-13
    your overall diameter is 23.19inch
    and your speedo is 1.8 percent slow i.e. if original speed is 100 km/h speedo will be showing 98.1km/h
    with 185-65-1
    your overall diameter is 23.46inch
    and your speedo is 3.0 percent slow i.e. if original speed is 100 km/h speedo will be showing 97.0km/h
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    guess? wat abt the calibration?
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    but than again the speedos by stock are usually a bit fast hence you will not be having significant difference
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    @ghuncha
    thanks sir jee. but tell me, is it bad for my suspension? and can i calibrate ma meter as per these tyres ?
    Ghuncha's Avatar
    Aug 2005
    35
    5,967
    19 Post(s)
    well bad for your suspension, i dont think so that much, i have used massive tires on corolla, although it affected the economy and stuff but suspension was fine, as afar as meter is concerned, its very difficult to calibrate, though i did it on myne but is a tedious process, as i said by stock usually speedos are fast and with your 185/65/14 tires your speedo will go slow by 3% and i think it will be balanced, still get the tires than contact me, i have gps speedo, we can see the exact error from it.
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    thank u so much sir. means a lot
    Vajih102's Avatar
    Oct 2004
    32
    14,339
    391 Post(s)
    10 Thread(s)
    Waleed bhai, rims gifted to you on your birthday? do the car a favour, leave them looking as nice as they currently are. the ONLY rims found decent till today are the genuine Toyota ones. those i think are 17".
  12. #12
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    14s for Platz Feasible ? -890846
    14s for Platz Feasible ? -890847
  13. #13
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    which one of above shud i go for ?
  14. #14
    razapower's Avatar
    Nov 2004
    40
    403
    go for 185/65/14
    I have them in my Yaris. No difference in drive comfort if tyres are soft.
    Meter readings are also almost the same. Checked it on speed gun 7th avenue .
  15. #15
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    @raza
    u r rite sir, but i got new 13s Yokohamas last year, only run for above 25k now. so cant sell at them at cheap rate. so i have decided to go for either of the above shown 13 in rims. which one u prefer
  16. #16
    razapower's Avatar
    Nov 2004
    40
    403
    go for 185/65/14
  17. #17
    mafzaltareen's Avatar
    Sep 2005
    2,269
    2 Post(s)
    i also had 14 inch rims in my platz the drive was good but i dont remember the exact profile.
    the first design is better
    http://www.facebook.com/V8Rx8
  18. #18
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    thanx. wud ;post few more to choose from inshallah tomorrow
  19. #19
    razapower's Avatar
    Nov 2004
    40
    403
    waleed check some more rims out. above ones are just ok.
    you can look for some original used ones in RWP, since they are lighter.
    The Chinese ones are as heavy as the local RIMs. only shashkaa nothing else!
  20. #20
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    @raza
    sir from where can i get the original rims in pindi. any idea ?
