Results 1 to 11 of 11
Thread: Air filter of my Platz
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    Default Air filter of my Platz
    Guys I have a problem with my car since i converted it on CNG 7 months back.Its air filter keep on burning due to back firing I guess.The last one lasted only 4 days.Experts plz help me out on this.
    FaToNe......
    faisal2193's Avatar
    Dec 2006
    38
    118
    plz check its air setting. Also put a little amount of mobile oil in Petrol Tank. Hope it will solve the problem.
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    It is happening due to improper adjustment of gas mixture, get it adjusted by a goog cng mechanic.
    Never loose hope in life,every step gives u something.
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    @faisal My car runs on CNG will adding oil to the petrol tank help?
    @argtr65 I went to the person who put CNG into it he told me to get the plugs replaced.Now he tells me to get the coils changed but this time I wont listen to him bcoz I think he is acting on his whims
    FaToNe......
    saadzae92's Avatar
    Mar 2008
    27
    999
    8 Post(s)
    https://www.pakwheels.com/forumreply_az_TopicID!100571~ForumID!10~pw.html
    Sir this thread might help you
    The only way to get rid of temptation is to yield to it... I can resist everything but temptation.
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    @saad thanx
    FaToNe......
    saadzae92's Avatar
    Mar 2008
    27
    999
    8 Post(s)
    no problem
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    @gamemaster
    i had the same problem on ma platz, and to be honest i think i still have the same problem. why ? because it only happened to ma car in summers when the AC was on. there was no problem of backfiring or the spark plug gap adjustment, still it kept on doin so. i have even posted the pics of ma filter in the topic i made for the exact same issue. search and u wud find it. still, if u have found a cure to it , wud u please like to share
    thankz
    argtr65's Avatar
    Dec 2008
    51
    1,645
    74 Post(s)
    7 Thread(s)
    @Waleed80,
    If it is happened only when A/C on,it means ur a/c is drawing excessive current causing voltage drop in ignition system causing for back fire, this is happened due to some loose electrical connection or defective relay.Try to trace out the problem with the help of any expert auto electrician.
    gamemaster's Avatar
    Dec 2005
    Hyderabad
    30
    305
    @waleed80 After trying everything the air filter keeps on burning :-(
    however 4 days ago on the advice of another mechanic I replaced the plugs with new bosch 4 point plugs (I got those 3 months back) and up to now it is working fine.I've got my fingers crossed but have a feeling it will happen again.
    FaToNe......
    waleed80's Avatar
    May 2006
    Rawalpindi
    36
    6,690
    36 Post(s)
    AH. dats one bad feeling dude :-)
