People driving honda... get their cars number plate installed with new holes to adjust the center for fitting.... i got an idea "DON'T MAKE NEW HOLES"
You'll need
1. Number plate frames (available in market 2 pieces for 150rs)
2. Drill machine (for making holes in the number plate frames)
3. 2 bolts and its nut ( make sure the bolts are flat headed)
4. Tools (for tightening the nuts)
The process
1. Measure the distance of holes given on the car (in city its 9.45 inches)
2. Measure the width of frame and the length... (mark the center vertically on both side)
3. Adjust the center horizontally and make the holes.
(if u r not sure about step 1,2 and 3 ask a number plate wala in he'll do the holes )
4. Before installing the frames insert the bolt from the back of the frame in the holes given by default in the frames.
5. Insert the number plate, and tighten the nut over the bolt, (if in case the bolts are moving with the nuts hold it by plass from the front end.
and you are done...
