AOA ,
a few questions ..1) how to clean the stains in side the bonut , caused by the (pani of battery) ?2) what is anti rust coating under the car? wats its price ? does it reduce the car pricee and how effective it is ?
thanks guys
Best anti rust coating is coal tar :+P...you call it 'lukk' in urdu.
Try surf for stains. If it doesn't work then try mild acid that radiator walas use. You can also try WD40 to clean it.
Sent from my Nexus S using Tapatalk 2
are u serious?dude seriously done try that!what u need to do is get all purpose cleaner by 3m,spray it on the stains n let it stay there for 5mins n then rub it off with a tooth brush,do this couple of time n ull be good to gothis can also be done by another liquid called 'pre-soak' it is a little agressive n more efficent as compare to apc,u can get pre-soak from @vague_one @ pw.
how do you expect to clean rust and acid stains with those cheesy cleaners, It needs a wash, sanding and painting. And then needs to be checked why the battery is boiling over.
u cant clean acid dagh with acid
i think ur rite but may be wd 4o r effort with these cleaners would help
baking soda would help ????????
battery acid stains cannot be cleaned. paint is already eaten and you can confirm it by chipping it with your nail.sand it and repaint that area.
Just spray oevr the WD 40 and kick out the exide pathetic battery out the car and hook up a mf battery.Its not your car,every second car has this problem,i don't know about fella's living abroad.
