Manufacturer: SONY
Type 4 Way
Size 16cm x 24 cm
Rated Power 100 Watts
Peak Power 420 Watts
Sensitivity 91dB
Impedance info n/a
Frequency Response 28 Hz- 35 KHz
Specification
420W Peak Power
Coaxial Full-Range 4Way speakers
GTX Series
6 x 9 Inch HOP Woofer Cone
Rubber Surround
Ferrite Magnet
General
Diameter 6 x 9 inches
Speaker System 4-Way Coaxial
Peak Power (W) 420
Rated Power (W) 100
Frequency Response (Hz) 28-35k Hz
Sensitivity 1W/1M (dB) 91dB/W/m
Woofer
Type HOP Cone
Magnet Material Ferrite
Magnet Size (mm) 100 x 15
Voice Coil Size (mm) 30
Mid Range
Type Cone
Material HDLD
Size (mm) 66
Magnet Type Ferrite
Tweeter
Type BD
Size (mm) 25
Manufacturer: Kenwood
Product MPN
MPN kfchq718
Key Features
Car Speaker Type Coaxial
Elements 3-Way
Car Speaker Function Subwoofer • Tweeter • Mid-Range Speaker
Size 7" x 10"
Nominal Power Handling 80 Watt RMS
Powered Non-Powered
Technical Features
Peak Power Handling 320 Watt
Frequency Response 22 Hz - 33 kHz
Sensitivity 93 dB
Impedance 4 ohm (Dual Coil)
Components
Tweeter Design Balanced Dome
Tweeter Size 1"
Woofer Material Poly / Plastic
Surround Material Rubber
Guys kindly suggest which one is better in sound, quality, bass. And suggest keeping in mind that i m going to play any one of them with a 800watts amp and 12" sub
