(UPDATE) : The car is sold now and I have uninstalled the stereo setup. Contact me on the number mentioned below to finalize a deal. Looking for a quick sale, so the prices have been reduced.
Asalam-O-Alaikum friends !
Up for sale is a rare SQ Audio Setup.
Reason for sale: I am selling my car, therefore selling the setup as well. ( Ref : https://www.pakwheels.com/forums/vehicles-bikes/210960-f-s-jdm-honda-accord-cf-3-2002-islamabad )
All the items have been gently used and are in top notch condition.
Amplifier - McIntosh MC420M -
(SOLD)
No introduction required to this !
Technical Specs:
50w x 4 @ 4 ohm
THD: 0.005%
S/N Ratio: 110db
Dimension: 362w 71h x 305d mm
Weight: 6.4kg
Amplifier ? Zapco Reference Series 360.4 - (SOLD)
? Designed and manufactured in US
? With complete box, warranty card, noise reduction kits, birth certificate
Technical Specs:
Stereo, 4 ohms: 4x50 Watts
Stereo, 2 ohms: 4x90 Watts
Bridged, 4 ohms: 2x180 Watts
T.H.D. + Noise: <0.032% @ 4 ohms
S/N Ratio: >95dB (not A-Weighted)
Slew Rate: >23V/uS
Damping Factor: >160@ 4 ohms
Dimensions: 18"L x 7.5"W x 2"H
-SymbiLink??? Balanced Inputs
-RCA Unbalanced Inputs
-2 ohm stereo stable
-18 dB variable bass boost control
-Dual variable electronic crossover
-Dual bridgeable @ 4 ohm
-Four channel
-High Current Bi-Polar output devices
-Optically isolated MOSFET power supply
-Switch for use as stereo, single L ch. or R ch. bridge
-L+R sum mono for use as a bass amp
-Surface mount technology w/1% resistors,
precision caps, and massive ground planes
Front Stage - Focal Polyglass 165V30 -
(SOLD)
? 30[SUP]th[/SUP] Anniversary Edition
? Hand made in France
? Complete box, manuals and warranty
Technical Specs:
[TABLE="width: 0"]
<tbody>[TR]
[TD]Cut-out diameter[/TD]
[TD]5-9/16" (141mm)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Woofer[/TD]
[TD]6-1/2" (165mm)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Tweeter[/TD]
[TD]TNB inverted dome[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Magnet[/TD]
[TD]3-1/3" (85mm)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Frequency response (+/-3dB)[/TD]
[TD]55Hz ? 25kHz[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Sensitivity (2.83V/1m)[/TD]
[TD]92dB[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Nom. Power[/TD]
[TD]80W[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Max. power[/TD]
[TD]160W[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Depth from wall[/TD]
[TD]2-13/16" (71.8mm)[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Product type[/TD]
[TD]2-way kit[/TD]
[TD][/TD]
[/TR]
</tbody>[/TABLE]
Coaxials - Focal Access 130CA1 -
(SOLD)
? Perfect surround sound
? Value for money
Technical Specs:
[TABLE="width: 0"]
<tbody>[TR]
[TD]Nominal impedance[/TD]
[TD]4 Ohms[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]117mm (4.6")[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Woofer[/TD]
[TD]130mm (5")[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Tweeter[/TD]
[TD]Aluminum inverted dome[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Voice coil[/TD]
[TD]25mm (1")[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Magnet[/TD]
[TD]85mm (3.3")[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]65Hz - 20kHz[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]91dB[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Nom. Power[/TD]
[TD]50W[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Max. power[/TD]
[TD]100W[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]56mm (2.2")[/TD]
[TD][/TD]
[/TR]
[TR]
[TD]Coaxial kit[/TD]
[TD][/TD]
[/TR]
</tbody>[/TABLE]
Centre Channel ? JVC CN100 -
(SOLD)
? Very hard to find in Pakistan
? Read to use
? On dash placement design
? No need to fabricate a pod
Technical Specs:
2 5/8" Center Speaker
Oblique Cone Mid-High
Neodymium Magnet
Rolled Butyl Rubber Edge
For further details, info on prices and deal finalization, contact: Faraz Mahmood 0334-5285270
