h3i got it in 16k/h3
h3/h3
h3NV-SW15/h3
NV Series 15" Subwoofer
Reinforced FUSION Torsion Arm Construction
NV Series adds heavy duty side extrusion bars to the already rigid FUSION Torsion Arm basket construction for incomparable stability of the motor structure
Triple Stacked Motor Structure
A triple stacked motor structure ensures intense sound generation, cradled in a one piece industrial cage for extra protection
Press-formed Paper Cone
Press-formed paper cone construction gives maximum thrust to competition level bass with ease
2" Core Vent System
Thermally efficient core exhaust vent rapidly diffuses heat produced during extended runs into extreme low frequencies
8 gauge oversized power connectors
Providing ease of connection and superior power transfer into the motor structure through enlarged contact area
Chemically Treated Suspension Dampener
Chemically treated in FUSION green and lab tested for lasting durability and dampening ability
h3Product Specifications/h3
Max Power Rating (Watts): 2500
RMS Power Rating (Watts): 1100
Coil Height (Hvc): 40
Compliance (Cms): 146.18
Cone Area (Sd): 77.93
D.C. Coil Resistance (Re): 0.88
Electrical Q (Qes): 0.552
Force Factor (Bl): 8.4
Free Air Resonance (Fs): 23.62
Frequency Response: 19Hz - 500Hz
Gap Height (Hag)(mm): 10
Impedance (Nominal): 1
Inductance (Le) (mH): 0.51
Linear Excurson (Xmax): 40
Mechanical Excursion (mm): 15
Mechanical Q (Qms): 6.17
Moving Mass (Mms):285.85
Sensitivity (dB) (1W/1M):87
Total Loudspeaker Q (Qts):0.506
VAS (L): 126.07
VAS (CuFt): 4.45
Magnet Structure (Oz): 308
Total Loudseaker Displacement (L): 12
