@f430yar me itna bhe expert nai hoonn...yar tere lluck the jo stuff tujhe mil gaya he...@dccoolguyenjoy ur stuff man!!
YouTube - cerwin vega 12" on SA~16d
you have the lethal combination
@spano: Hell Yeah! I Am Changing The 307 With A 305C Soon And Upgrading To A Better Amplifier...
@rockk: Chalein Luck Bhi Hai Mger Aggar Aap Na Hote Tou Kahan Se Miltaa?
ha haa...ok brooo
@rockk: Aapne Enerlevel ka reply parha? Kuch samajh aata hai? Mujhe Samjh nai aayi what he wanted to say..
@f430 : he said install another d4 instead of 306c and connected both at 1ohms load on amplifier,it'll perform good and the subs will get more power from the amplifier...........
@smartboy: Thanks.. I Am Thinking to Switch Both To SVC Or DVC..Probably I Am Thinking Of A 305C Instead of the D4..
yea 305c wud be better than d4 gud luck!
305C Is a lot beter thn d4...d4 to farig hee...
Oka Fer! 305C Done!
305c done hee to phr laboo janab woofer....
I am in love with Solid Audio Mono block amps ( for small budjet / power ) this is really cool , just checked your video and woofer`s excursion tells me the power of amp
for nice cash ( branded Cea Rated Amps only )
@geforce: At The First Day I Installed It To The 306C Only, The RCA Cables Were Not Secured Properly And Were A Little Loose..I Became Really Dissappointd To Spend That Mutch And Get Something Which Was Not Running A Single Sub Properly!! The Problem Was Solved Later When One Day I Found The Cables Loose..Then I One Day Experimentally Attatched The 307D4 To It (which was running on a separate amplifier) And The Result Was Just Awesome!
@rockk: Buss Bhaijan Parchay Hojaen..I'll be Free On 21st Dec!
nice
solid audio rockks....@f430bhia jaan itnee jaldi disappoint nai hoo jate....ap koo pata hee hee the cables u got with ur old setup...thy wer just rubbish....
^ Yeah Right!I Am In Love With Mono Blocks! Apparently With Solid Audio!..
For how much did u get the kenwood player?
