Sirs
Get 1 12" Type R or CV in a good sealed enclosure, 1.5 Cu ft will be more then enough if you have good enclosure.
I think there is an Excelon 10" available in Karachi, small sub will generally require small enclosure and less power but the bass cannot compare with the 12" one, the price will be qual to a 308.
@RAcEkrAzE<SCRIPT type=text/javascript> vbmenu_register("postmenu_2301186", true); </SCRIPT>
Sir the presentation is good but they are taking up the same space, on the negative side there is no space left for wider items.
Regards
